Is my starter too hot?
EXTRPR50
370
Hey guys, I have noticed on my 91k 5-oh, 5spd notch that after a long ride, when I turn off the car, then crank it up again, it just clicks. All my electronics like fuel pump, door chime, and gauges come right up. It's just a click! and nothing. If I let it sit it will start up again.
So is this my battery, starter, starter relay, solenoid? Oh yeah, my battery cables on the post become extremely hot. I found that out by seeing if they were loose.
Thanx fellas.
Sounds like something is deffinetly getting hot. I would think maybe a bad connection at the battery might be a thought. It might be tight, but it could also be corroded which will also cause it to heat up. You could try putting some wrap on your starter or make a small heat shield.
No lt's, and the terminals are not corroded in the least. Is there a company that makes a heat shield?
It has a powerful engagement of the starter, its just like it hits it and it cant spin the flywheel. Im stumped.
you have bad cables/starter solenoid...i would replace your ground cable(use two 4ga ground straps, one from the block to frame, and one from the frame to battery..) Also run a new starter RED cable..get the thickest guage you can find. Your cables getting hot is a bad sign, i'm 99% sure the starter is fine..with heat comes resistance, the more heat in the wires the less voltage they let pass through
you probably have a corroded spot on the wires. you could get a clamp on style ammeter to see if you are getting a dead short. also check your battery if it is old. if it a couple years old it should be ok. if the starter gear is engaging the flywheel and not turning it, cause maybe the starter has a little heat soak and the battery cannot provide enough ummph to turn it over.
Yes, the things that come on like the fuel pump. door chime and gauges go off when the click happens, but when I let off they come back on strongly. Thats what makes me believe the battery is ok.
I would bet on a corroded cable, poor connection to the battery, or some corrosion on the terminals.
The wiring can take a small load, but when you go to start it cannot draw enough to turn the engine over.
