Is There A Complete New Efi Solution?
  • Thread starter Thread starter 94Blue302GT
  • Start date Start date Mar 27, 2014
94Blue302GT
704
Chicago
Mar 27, 2014
  • Mar 27, 2014
Ok guys, I haven't been on here in AGES, but here I am...
Simply put, if I built a motor... say a 347 Dart with AFR 185's and some fancy intake (Looking for 6500-7000 peak hp) is there any way to do aftermarket EFI with a MAF on this thing?
I know they sell the harness aftermarket at a few places, but I was having a hard time finding anything in the way of a computer. Using an "old" computer is not appealing for this setup.
Or do I have to forgo the MAF and use some jack in the box MAP universal system?
Right now it's theory crafting. It's actually for a boat. A boat I'm tired of doing only 50 in, lol!
As it's a boat, I would really really want stuff to be reliable and while my 94 was reliable, I don't want to put something that old electronically into my boat.
Thanks in advance guys!
Lee
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Mar 27, 2014
  • Mar 27, 2014
If you're going to go to the trouble of an aftermarket computer and wiring harness, why go mass air at all?
Reactions: tannerc91gt
rbohm
6,698
550
204
tucson,az
Mar 28, 2014
  • Mar 28, 2014
good question. the reality is that you dont need mass air for a specific application. mass air is nice for a factory set up, but these days the aftermarket systems are either very easily tunable, or they tune themselves more easily than a factory system does. the only reason to use a factory type system is the ease of troubleshooting by being able to pull computer codes to set you in the right direction.
personally i would go with something like a megasquirt system if you are willing to tune it yourself, or with something like a F.A.S.T. or edelbrock system that tunes itself.
94Blue302GT
704
Chicago
Mar 28, 2014
  • Mar 28, 2014
Hmmm, I always thought maf was the way to go. Have had problems with my dodge and elevation changes.
Burnt plugs in 8 hours of driving through mountain before and never had that with a Ford maf vehicle.
In any case, those systems look good and costs weren't too crazy. This is a 3 year project at best so I will advise of build if it ever starts!
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Mar 28, 2014
  • Mar 28, 2014
big stuff 3 or the new holly dominator system... only 2 worth looking into honestly
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Mar 28, 2014
  • Mar 28, 2014
I run a holley HP efi system, same as the dominator, except that with the dominator system you get more inputs and outputs. The inputs are used to monitor anything you want... literally anything that the car does, if you can put a sensor on it, you cant monitor and datalog it. The output are for things like electric fans that the computer can turn on or off.
MAF's arent needed one bit. I drove my car thru 5 states in 5 days and it went from 95 and so humid i had trouble breathing at times, to 65-70° and zero humidity on the last day and the computer didnt miss a beat. The fuel table is self learning so as conditions change, so does the fuel map.
Reactions: A5literMan
stykthyn
5,232
2,652
223
gainesville
Mar 28, 2014
  • Mar 28, 2014
If its for a boat why not a dual carb set up?
94Blue302GT
704
Chicago
Mar 28, 2014
  • Mar 28, 2014
I know less about carbs, I like the tunability of a computer, and fuel injection "typically" gets better mpg.
I looked at it though for simplicity
Reactions: 90lxcoupe
bentley429isBAC
922
188
84
CT
Mar 28, 2014
  • Mar 28, 2014
Holley.
MikeH686
Mine is only two inches though.
2,843
1,753
184
Waldorf, MD
Mar 29, 2014
#10
  • Mar 29, 2014
  • #10
Isn't the Holley more based towards gm based motors?
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Mar 29, 2014
#11
  • Mar 29, 2014
  • #11
If it were for a boat, I would just throw a carb on it.
Kurt
94Blue302GT
704
Chicago
Mar 29, 2014
#12
  • Mar 29, 2014
  • #12
Maybe I don't know much about carbs, but wouldn't I have to re jet it for different elevations? We take it a lot of places. Figured efi would compensate for it where a carb wouldn't.
Doesn't efi also make more power and use less gas? Those both sound good to me!
Then again so does the simplicity of a carb.
What about e85 in either one? Do they make a flex fuel system? Sorry just daydreaming there
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Mar 29, 2014
#13
  • Mar 29, 2014
  • #13
I don't know much about carbs either. I do know that most of those full aftermarket EFI setups aren't known for reliability. Getting stuck out on the lake because some small electronics has failed kind of sucks. The carb would be super reliable. Any change in performance between the two would be negligible. Fuel injection is a lot more efficient in cars, where throttle settings change constantly, and you idle a lot. On a boat where you have pretty constant power settings, it doesn't make much difference. It's the same with airplanes. The fuel injected piston airplanes don't get any better burn rate than the old carb ones. A change in elevation shouldn't require a re jet. It might not be spot on all the time, but it should be close. I would seriously talk to someone who does boat engines. The guy who builds my engines is pretty much the authority in boat racing engines. He builds for all the winning offshore racing teams. I don't think you are going to have much luck with your build. An engine that makes good power in a car at 6500-7000 rpms is different from a boat engine that makes power up there. The difference is duration. In a street car, you have it in that rpm range for a few seconds at a time. In a boat you have it up there for long periods of time. A valve train that doesn't fall apart in a few seconds in a car may not make it for 30 minutes at a time in a boat.
This is the guy I use, and about half of his business is high performance boat engines. Look through his website if you want to get some ideas.
http://expressenginesusa.com/
Kurt
Reactions: stykthyn
stykthyn
5,232
2,652
223
gainesville
Mar 29, 2014
#14
  • Mar 29, 2014
  • #14
Helped build a marine 350 once. Had to use a new cam, lifters, and springs to ensure constant hi rpm use. It was carbed from the get to so I can't say how to fit efi on one.
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
7K
Other Auto Tech Jul 28, 2024
manicmechanic007
