I'm not talking about individual cylinder compression like you'd do to see how good your rings seal, i mean like compression ratio. Aside from knowing what cc your bowls are and pistons are?
the compression ratio is just a mathematical calculation of known volumes, mostly the ones 347HO listed, but if you want to get anal, you can add the tiny volume that is between the piston and the bore above the top compression ring.
