Is This A Good 393 Stroker Combo?
  • Thread starter Thread starter wickedmach1
  • Start date Start date Jul 8, 2004
W
wickedmach1
376
Austin, TX
Jul 8, 2004
  • Jul 8, 2004
Car = 1970 Mach 1 w/ 3.89 Gears and True-Trac Rearend = STREET CAR
1969 351w Block Bored .030" Over
FRPP LINK BAR Hydraulic Roller Lifters
AFR 205 Cylinder Heads
393 SCAT 9000 Crank and 5140 I-Beam Rods, SRS Probe Forged
Pistons with large reliefs (10:1 CR), Clevite Rod/Main Bearings
Hydraulic Roller Custom Cam (Duration=240's, Lift=.600's, Lobe Seperation=112)
Billet Timing Set
Speed Demon 850 MECHANICAL Secondary Carb
Pro Magnum Roller Rockers
ARP 1/2" Head Studs
Vic Jr. Intake #2981
1 3/4" Shorty Heads w/ 3" Exhaust From Front to Rear
G-Force T-5 Tranny
Good or bad? Any improvements??? Thanks.
65fastback2+2
1,229
Louisville, KY
Jul 9, 2004
  • Jul 9, 2004
change the t-5 to a built c4 with the gear vendors gear drive, t-5 isnt gonna handle a 393W for long
SadbutTrue
2,391
Thousand Oaks, California
Jul 9, 2004
  • Jul 9, 2004
if you really want a 5 speed, you're gonna want a TKO, I hear very mixed thigns about the Geforce. Other than that.. that thing is going to scream...
brianj5600
1,964
Middle TN
Jul 9, 2004
  • Jul 9, 2004
The only reason I'd build a 393 over a 408 is to save money by using stock rods and 302 pistons. If I was buying everything, I'd get the extra 15 cubes. Looks good though, who is doing the cam?
W
wickedmach1
376
Austin, TX
Jul 9, 2004
  • Jul 9, 2004
Comp Cams for the camshaft.
What is all involved by using the new TKO tranny in a '70 Mustang? How much harder is it to make fit over a T-5? If I use all G-Force internals, you don't think it can handle the torque? I wanted to go G-Force since I have a core and it fits without cutting the tunnel. But if I will have problems, maybe the TKO is the better way to go.
xoxbxfx
3,959
Southlake, TX
Jul 10, 2004
  • Jul 10, 2004
The TKO is an easy swap... You will need a tremec crossmember and to shorten the driveshaft a little I believe. The Gforce isnt gonnahold for long, its a little baby tranny. I wouldnt waste my time with it. A TKO isnt much more.You dont need to cut the tunnel, hell... A 69-70 will hold an AOD without any problems
blown65
1,938
Queen Creek Arizona
Jul 10, 2004
  • Jul 10, 2004
Gforce T5 will handle the power and you dont have to mess with all the BS of getting a tko to fit. You guys need to research some on the gforce, they are stout trannies.
Only thing I guess is the cam, not saying its not good but get a good recommendation from crane or lunati. They can punch in all your specs you have and give you a good cam for what your doing.
U
usedtobe 67p51d
208
let's tear up golfcourses and build race tracks!
Jul 10, 2004
  • Jul 10, 2004
t-5 problems start with the case.
It is flawed from the start
if the case is weak, when you lay on the horsepower the gears walk away from the main shaft and that's the start of failure. the tremec will handle more hp but it's larger as far as fit it should go in I'm running one in my '67 it's tight and I would love to cut the floor for an extra degree or two but with tcp motor mounts,dark horse tranny mount& an aluminium driveshaft it feels fine as far as your motor goes it sound about right,
the only thing that I would change on my motor would be I went with the comp cames top of the line roller rockers is that I would have gone with a set of shaft mounts...I broke three studs all at differant times untill I added a rocker arm girdle set,... mucked up a set of valve covers as well
side note would be a B I G O I L P A N the more oil the better
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
For Sale 1986 Capstang (Part Capri & part Mustang) $12,000 Galena, Ohio
  • BubbaG
  • Aug 7, 2022
2K
Fox Body Mustangs For Sale (1979-93) Aug 7, 2022
General karthief
P
2018 Rims on 1965 Mustang
  • PsuedoCode
  • Nov 15, 2021
2K
1965 - 1973 Classic Mustangs -General/Talk- Nov 15, 2021
PsuedoCode
P
73 mustang blower build info needed
  • 73stang347
  • Sep 20, 2018
1965 - 1973 Classic Mustangs -General/Talk- Sep 21, 2018
rbohm
SOLD 1991 LX hatch 5.0 (347/TKO) Elgin, Texas
  • LarsD
  • Sep 20, 2019
3K
Fox Body Mustangs For Sale (1979-93) Sep 20, 2019
LarsD
