Is this a problem?
  • Thread starter Thread starter Fireman255
  • Start date Start date Jul 26, 2005
F
Fireman255
119
  • Jul 26, 2005
A friend and I installed my intake yesterday and we didn't use any gasket in the front or rear. It seems as the front is not seating all the way down to the block, it looks as if there is a 1/8" gap between the intake and block, it is filled with RTV but wil lthis be a problem / Has anyone else experienced this? The intake seats to the heads just fine.
Any input would be great, just want to make sure that it is kosher before we finish.
Thanks
65up2d8
281
Memphis, TN
Jul 26, 2005
  • Jul 26, 2005
If you're talking about the gaskets that go in the front and rear of the lifter valley, which it sounds like you are, I've heard many people say that they don't use the gaskets that come with the set and just use RTV, so it should be fine. Its been so long since I changed my intake that I honestly don't remember what I did. It sounds like you should be fine, though, based on what others have said.
F
Fireman255
119
  • Jul 26, 2005
ya I am just trying to make sure that that 1/8" gap is ok.......if it is I think I will goopit up with some more RTV to make sure there will be no pin holes
70XR7ConvertCat
Livermore, California
Jul 26, 2005
  • Jul 26, 2005
No one really uses the rubber gaskets in the front and rear, because they usually wind up leaking. A good bead (3/8") of RTV will close that gap nicely, and it won't leak.
66ford289
100
  • Jul 26, 2005
I used RTV to seal it up, there is a little gap on mine. I don't think you have any problem.
hungrymonkey
White by Birth, Trash By Choice
12
108
Oregon.
Jul 26, 2005
  • Jul 26, 2005
geez mikey, have no confidence in me
j/k
D
D.Hearne
11,730
south louisiana
Jul 27, 2005
  • Jul 27, 2005
Speak for yourself. If they're in the gasket set, I use em. And mine never leak. Felpro's newer intake gasket sets with the cork end gaskets have an adhesive on the block side, just peel the paper off, stick em on, and they're guaranteed not to poke out when you torque the intake down.
jikelly
20+ Year Stangneter
Jul 9, 2003
872
53
99
Lubbock Tx
Jul 27, 2005
  • Jul 27, 2005
I like RTV. It stands next to duck tape as one of man's greatest inventions.
Edbert
3,548
32
109
Austin TX
Jul 27, 2005
  • Jul 27, 2005
I've seen both methods work and I've seen them both leak. Bottom line is that if you get a leak you'll have an oily mess on your hands.
hungrymonkey
12
108
Oregon.
Jul 28, 2005
#10
  • Jul 28, 2005
  • #10
we got it running yesterday, and it leaked
have to pull the intake and goober some more on.
I was having some problems remembering which way the dizzy spun. so timing was a little bit goofy, then the metal parts of the plug wires were pulled back into the boots so it ran like crap until we figured it out.
carb fires are exciting.
D
D.Hearne
11,730
south louisiana
Jul 28, 2005
#11
  • Jul 28, 2005
  • #11
Good Old HungryMonkey............. Always good entertainment
hungrymonkey
12
108
Oregon.
Jul 28, 2005
#12
  • Jul 28, 2005
  • #12
forgot to mention it was around 100* yesterday so we were both sweating like dirty pigs.
we had to set the idle high beacause of the vacuum leak, so every time it was put in gear it chirped the tires.
we did learn some key points yesterday. studs and bolts on an intake suck. the dizzy spins counter clockwise, heater hoses are hot, anything left in the sun is hot, and motors are really loud when you forget to put the #1 sparkplug back in.
But if you revert back to the air, fire, and fuel concept, then its fairly easy to trouble shoot.
Is the motor breathing (air through the carb)
is it circulating gas through the carb?
is the fuel being ignited (spark)
if any of those are not occuring, then you stand back and curse until you figure out what it was that you broke.
F
Fireman255
119
#13
  • Jul 28, 2005
  • #13
Took it all back off and put more RTV on it and another set of new gaskets as the others riped on removal. So hopefully It will run well after the RTV dries...... by the way how long does that take?
SoCalCruising
2,437
SoCal
Jul 28, 2005
#14
  • Jul 28, 2005
  • #14
24 hrs, I believe, before you should fire it up.
Max Power
1,774
St Paul
Jul 28, 2005
#15
  • Jul 28, 2005
  • #15
I always use those gaskets. I had an air pocket on the rear bead once and it leaked and I have been using them since.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Jul 29, 2005
#16
  • Jul 29, 2005
  • #16
Something else you can get are silicone intake end gaskets. I had some that came in a 5.0 gasket set. They have littles bosses that lock into holes in the block and you can install them dry save for where the intake/end gaskets meet. They squeeze like hell, but dont break.
pabear89
2,126
High in the Hills of So Ca with the Voices in My H
Jul 29, 2005
#17
  • Jul 29, 2005
  • #17
Ahhhh.......But Your Learning GrassHoppa...........
Thanks I needed that!
hungrymonkey
12
108
Oregon.
Jul 30, 2005
#18
  • Jul 30, 2005
  • #18
I wasnt joking actually
I have a feeling that fireman's neighbors kids think that my mom works for a truck transport agency.
mother trucker
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
