is this a racing cam???
1FatPony
241
I am looking at the 87 5.0 mustang and the owner says the previous owner put some aftermarket cam and some other little things in the engine. He says it has somewhat of a "rough" idle but says thats what the racing cam is suppose to do. It has 132,000 miles. i am not too familiar with aftermarket cams so is this guy for real or is he bs? Is the rough idle from the cam or a bad engine?
most aftermarket cams will make the idle rough. but a cammed idle isnt really rough its lopey. a rough idle like a surge or a idle that spits and spudders is just a crappy engine.
ps. tell the guy that all cams arent racing cams
its a huge valvetrain manufacturer.
if the car lopes like a race car, it probably has a higher duration aftermarket camshaft. the term "race cam" really means nothing.
to tell if its a cam or a bad running engine.
rev the engine up if it revs smoothly and has a lopey idle its a cam.
if the engine runs bad and still does when u rev it, its most likely engine related.
my car has a cam and lopes like a mother and sounds like it will die lol but when i rev it to start driving, it sounds and runs smoother like any other 5.0 liter.
See if you can get the car out on a test drive solo. Then take the car to a shop and pull the codes. That will give you a good idea of what you have to deal with.
Most codes are easy to fix, so don't be discouraged if you get several.
Let us know what end up doing
jason
