Is this detonation?
Nov 21, 2011
71
There is some ticking coming from behind the upper manifold and also a small pinging sound =(
I think (but im not sure) it started after I adjusted the timing. With the timing set at factory 10 btdc the engine is quieter and I can hear the sound loud and clear when I advance the timing I still hear it but barely. Whether I retard or advance I still hear that sound. I cant really hear it from inside the car either (with the top down)
2. in the second video towards the end, there is a gargling sound coming from my cai wth is that?
I have an mac cai with a sleeve going over where the maf sensor would be (my 87 doesn’t have maf)
My car still has that annoying power loss but runs a little better with the advanced timing. I use 91 oct
Thanks guys
Ping
Gargle
Thread moved to technical forum.
The good news is that, No... it's not detonation. The bad news is that it could be a host of other things.
Have you pulled the valve covers yet? Could be a broken/loose rocker, broken valve spring, dead lifter, bent rod, and the possibilities could go on and on.
What's your oil pressure?
Have you pulled codes?
How many miles on the car?
What were the circumstances when you first noticed the noise?
Do a cylinder balance test.
1 thanks, ive never pulled valve covers before, Im not that experienced (yet)
2 my oil pressure is good koeo and koer
3 my codes are all egr related (thats a whole nother story i havent fixed) see here: http://www.stangnet.com/mustang-forums/threads/catalytic-converters-help.849786/page-2
4 close to 200 thousand
5 i was under the hood looking at something and im not sure if it was before or after the adjusted the timing when i noticed.
6 will try the balance test this weekend thanks
all stock except: wires, ignition coil, cai, cap, cut off at the H pipe only two cats
thankshttp://www.stangnet.com/mustang-forums/threads/catalytic-converters-help.849786/page-2
just for S&G's, did you take the spout plug out before you did the timing? I would say that valve cover needs to come off there and inspect whats going on under it.
Cylinder balance test:
Revised 30-July-2011. Added need to make sure the clutch is pressed when dumping codes.
The computer has a cylinder balance test that helps locate cylinder with low power output. You’ll need to dump the codes out of the computer and make sure that you have the A/C off, clutch depressed to the floor and the transmission in neutral. Fail to do this and you can’t do the engine running dump codes test that allows you to do the cylinder balance test.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C clutch depressed to the floor, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Here's how to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and drivability problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, clutch depressed to the floor and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Warm the car's engine up to normal operating temperature. Use a jumper wire or paper clip to put the computer into test mode. Start the engine and let it go through the normal diagnostic tests, then quickly press the throttle to the floor. Remember to keep the clutch pedal (5 speed) depressed to the floor during the test.The engine RPM should exceed 2500 RPM's for a brief second. The engine RPM's will increase to about 1450-1600 RPM and hold steady. The engine will shut off power to each injector, one at a time. When it has sequenced through all 8 injectors, it will flash 9 for everything OK, or the number of the failing cylinder such as 2 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures.
Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
Do a compression test on all the cylinders.
Take special note of any cylinder that shows up as weak in the cylinder balance test. Low compression on one of these cylinders rules out the injectors as being the most likely cause of the problem. Look at cylinders that fail the cylinder balance test but have good compression. These cylinders either have a bad injector, bad spark plug or spark plug wire. Move the wire and then the spark plug to another cylinder and run the cylinder balance test again. If it follows the moved wire or spark plug, you have found the problem. If the same cylinder fails the test again, the injector is bad. If different cylinders fail the cylinder balance test, you have ignition problems or wiring problems in the 10 pin black & white electrical connectors located by the EGR.
How to do a compression test:
Only use a compression tester with a screw in adapter for the spark plug hole. The other type leaks too much to get an accurate reading. Your local auto parts store may have a compression tester to rent. If you do mechanic work on your own car on a regular basis, it would be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the throttle wide open, crank the engine until it the gage reading stops increasing. On a cold engine, it will be hard to tell what's good & what's not. Some of the recent posts have numbers ranging from 140-170 psi. If the compression is low, squirt some oil in the cylinder and do it again – if it comes up, the rings are worn. There should be no more than 10% difference between cylinders. Use a blow down leak test (puts compressed air inside cylinders) on cylinders that have more than 10% difference.
See the link to my site for details on how to build your own blow down type compression tester.
Edit: Nevermind someone already asked about the spout connector.
But if you did unplug the spout to set base timing and then plugged it back up, the ECM will adjust the timing advance automatically for you afterward.
