is this hard on new engine
dadiesel5
31
i finally got to drive my car tonight with the fresh rebuilt engine and the car has probably about 40 min of run time just idling at diffrent rpms and when i took the car out tonight i just had to see what it had so i got on it pretty hard taching it up to about 5 to 5500 rpm a couple of times but then started taking it easy on the motor and plan on taking it easy for around 500 miles, do you think i could have hurt my motor by doing this.
in the first 20min of runtime on my buddy's old 454 BBC he took it to 6500 RPM's on the back road behind th emuffler shop, that motor obviousely has long since gone POOF, with a flat cam(starved of oil and never broken in)
~Mark~
Probably not depending on rings.Roller motors and moly rings have pretty much made a "break-in" procedure a thing of the past.My race motors always got a few warm ups and leak checks before hitting 7800 at the track,never had a failure.I change the oil after warming up twice and then at 500 miles.
one more thing i've been having some header glowing issues and played with the timing till i got it up to around 18 or 19*and it took the glow out except for the driver side header this is at about 1600 rpm idle and when i back it down to 900rpm it goes away and also when i drove it i would get out and check it and it was not red but when i'm driving it and when i push the clutch coming to a red light it just goes dead and i have to restart it. what could be causing this. my cam was not degreed he just lined the dots up on the gears. thanks for your help.
when i fired my rebuilt engine up i used to old method of going out on the backroads and GETTING ON IT, 2nd gear went from 20-55 and let off and let the car decelerate on the rpms pulls alot of vaccum and keeps the engine well lubed. i did this about 10-12 times
no problems from my engine
i like to think of it this way.
if something in a new engine is going to break its going to do it within a minute or two after start up. it most likely wont just suddenly blow up 2k miles later
there are countless methods on what to do with a new engine.
and 99% of engines come out alright so imo it doesnt really matter.
only thing i would definatle avoid is cruising on the highway at a constant rpm for very long, vary your rpm take it up take it down. dont let it sit i one spot for long for the first 500 miles.
The motors we build in our shop, we break them in how they are going to be driven.
The first 10-15 for the cam shaft to break in, but after that its balls out on them
We have yet to have a motor come apart, other than fatigue/wear on stuff that doesnt last for ever
the car a 1993 5.0 just rebuilt with stock rods and crank new forged trw piston trickflow h/c/i 65mm throttle body stock fuel pump stock injectors stock regulator, do any of you have any idea about the header issue and the problem with the car going dead when coming to a stop.
I believe the header issue might be some unburned fuel making it into your header manifold tube...keep playing with the timing.
As for your break-in, I'm quite sure it is fine. Bringing the revs up and then letting it engine brake increases cylinder pressure/heat and therefore ring seating. But as stated, probably didn't have to go that far up in the revs, but I'm sure it is okay.
I changed my oil 3 times before 500 miles. The first was the 'dirtiest'...with all the lube mixed up in the oil.
