  • 1994 - 1995 Specific Tech
Is this normal? Please help
  • Thread starter Thread starter 94gt_vert_proch
  • Start date Start date Apr 12, 2009
9
94gt_vert_proch
10
  • Apr 12, 2009
Whats up guys. I just put my trans back in along with a new flywheel and i reused my low mile king cobra clutch. Now when i install my clutch cable and put the trans in gear with no driveshaft installed the output shaft spins freeley (in Gear) . When i take the cable off it is locked (Will not spin) . It seems like the cable is way too tight. I have to pry the clutch fork about 1 - 2 inches just to get the cable on. Anyone know what is going on here? is there any way to add slack in the cable? The way it sits now the clutch will not grab whith the cable connected I can rotate the trans with my hand. This is with a stock clutch cable quad no firewall adjuster.
Please help.
Thanks.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Apr 13, 2009
  • Apr 13, 2009
It should require some effort to put the clutch cable back on the fork, as it needs to have some preload, even from the factory. It's probably out of adjustment now though, so that's a simple fix. Reach up under the dash and grab the pawl and release it from the quadrant. Don't be alarmed if it pops as the quadrant releases. While holding it, lower the clutch pedal to the floor and release the pawl. Raise the pedal back up and it's now self adjusted.
desertcox05
379
south atlanta
Apr 13, 2009
  • Apr 13, 2009
+1 assuming you are using the stock quadrant
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Apr 13, 2009
  • Apr 13, 2009
Um you dont adjust a stock quadrant like StangGT1995 said. What i did is put my foot under the clutch pedal and pull it up with my foot. You will hear it pop or click,then push the clutch in i kept doing that and mine is just fine. At first (cause it was out of adjustment) it was just like yours tho. peace
john
BlownFiveLiter
18
108
Chicagoland
Apr 13, 2009
  • Apr 13, 2009
john
You do when it's set too tight, unless you want your clutch to slip like all hell, such as when you replace a clutch.
9
94gt_vert_proch
10
  • Apr 13, 2009
Thanks for the reply.
Do i do this with the clutch cable attached to the clutch or do i remove it first?
Also how do i release the pawl from the quadrant?
Thanks Again.
BlownFiveLiter
18
108
Chicagoland
Apr 14, 2009
  • Apr 14, 2009
The pawl is basically just a spring loaded ratchet that grabs onto the quadrant. You just have to hold it away from the quadrant, so you can lower the pedal, since it only ratchets one way. I don't really know a way to describe it, except that you hold pressure on the opposite end of the pawl than where it meets the quadrant.
9
94gt_vert_proch
10
  • Apr 14, 2009
So i do this with the cable connected to the clutch first right?
Thanks for the help.
BlownFiveLiter
18
108
Chicagoland
Apr 14, 2009
  • Apr 14, 2009
Correct. The quadrant will probably bang as the tension releases on it, but then you can hold the pawl and lower the pedal to the floor.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
