  • SN95 4.6L Mustang Tech
Is this normal ?
  • Thread starter Thread starter Killa
  • Start date Start date Dec 24, 2007
Killa
1,006
56
49
Dec 24, 2007
  • Dec 24, 2007
About 5 month ago or so I did the PI intake swap, my coolant was full until today I saw the low coolant light on, so I add more coolant, driving all day and the light and the light not come on, im I loose coolant like this every 6 month is normal ? how often is coolant burn away ?
Spro
73
IL
Dec 24, 2007
  • Dec 24, 2007
No that is not normal. Your losing it somewhere. Get a pressure tester from autozone and check the system.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Dec 24, 2007
  • Dec 24, 2007
What's your oil looking like? If it's getting creamy, or mily between changes, you might have a head gasket issue. It might also be a slow leak on the intake side, but like stated above a pressure test will give you a better idea as to what's wrong.
Killa
1,006
56
49
Dec 24, 2007
  • Dec 24, 2007
how much is pressure test and what its look like ? how to use it too ? LOL thanks
Spro
73
IL
Dec 24, 2007
  • Dec 24, 2007
Autozone will loan it to you for free. They are really easy to use. They'll show you. Good luck.
Bad92GT
The 5 Minute Plan Man
Jun 10, 2004
492
SC
Dec 24, 2007
  • Dec 24, 2007
just throwing it out there but it could have very well had a bubble stuck in the intake from the swap, and it just happened to finally pass out of the intake so it looks like you need coolant when all you actually did was burp the system.. mine kept needing it over and over till it finally started holding the level.. never had any water in the oil either.
forum155pl
520
the 509
Dec 24, 2007
  • Dec 24, 2007
crank the heater on and let her warm up.. i always try and park it on a hill with your front end up in the air to help burp the system..also squeazing the main rad hose a few times will tell you if coolant is fully purged. +1 on the tester too
Killa
1,006
56
49
Dec 26, 2007
  • Dec 26, 2007
I burp it by parking up on the hill. Car ran great and not loose coolant now. Thanks all you guy.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
