is this timing ??????????
  • Thread starter Thread starter hulk_lil87gt
  • Start date Start date Sep 1, 2009
H
hulk_lil87gt
47
  • Sep 1, 2009
ok i had a no spark issuse do to and bad modual. got a new dist. from a buddie of mine. put it in and the car fired right up reved it up a bit and wen the rpms dropped the car died. started it again let it run for about 15mins my uncle comes over and turns it off pulls the spout and gose to start it again it tryto start then died. went to start again and all the car did was turn over o and after the frist i guess just turn over i put the spout bac in and the car just keept on turning over. i checked everything againg for power and spark everythikng was good...
please excuase my grammer and spelling...
HISSIN50
34
129
Sep 2, 2009
  • Sep 2, 2009
Where did you set the timing? If it's set too retarded, it could act like this.
Did you check to see if the plugs were fouled? Cranking it with the gas pedal to the floor (only floor it while cranking - be ready to let off as soon as it starts) will shut the injectors off, which helps dry the plugs.
Otherwise, you're going to have to check fuel pressure and injector pulsing. You can run Jrichker's Cranks but no-start checklist in the Useful Tech sticky.
Good luck.
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Need help 1995 mustang wiring
  • bugz
  • Apr 14, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 14, 2025
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
