is this timing ??????????
hulk_lil87gt
47
ok i had a no spark issuse do to and bad modual. got a new dist. from a buddie of mine. put it in and the car fired right up reved it up a bit and wen the rpms dropped the car died. started it again let it run for about 15mins my uncle comes over and turns it off pulls the spout and gose to start it again it tryto start then died. went to start again and all the car did was turn over o and after the frist i guess just turn over i put the spout bac in and the car just keept on turning over. i checked everything againg for power and spark everythikng was good...
please excuase my grammer and spelling...
Where did you set the timing? If it's set too retarded, it could act like this.
Did you check to see if the plugs were fouled? Cranking it with the gas pedal to the floor (only floor it while cranking - be ready to let off as soon as it starts) will shut the injectors off, which helps dry the plugs.
Otherwise, you're going to have to check fuel pressure and injector pulsing. You can run Jrichker's Cranks but no-start checklist in the Useful Tech sticky.
Good luck.
