Is this what I need?
  • Thread starter Thread starter EXTRPR50
  • Start date Start date Dec 14, 2007
EXTRPR50
370
  • Dec 14, 2007
I am going turbo kit in my 93 stang in a few months. I know my stock t5 aint gonna do it. So, I have the ability to get a rebuilt z-spec t5. It's 1100.00 and that includes the take out and install. Will this hold up to a 8-10 psi stock engine? And how is the price? Thanx
Sicarius428
2,085
Dec 14, 2007
  • Dec 14, 2007
I have a feeling that it won't hold up. The Z is only rated to 330 from the WC's 300. It really depends on your traction and how you drive it but I wouldn't want to spend a grand on something that I(knowing me) would beat on. If you are on a tight budget I would look for a used(not beaten) TKO-3550. They can be found for a reasonable price compared to the tko 500/600. With the 3550 you will need a different bellhousing and crossmember... not sure about the driveshaft yoke...
Kevin
NKau
1,346
Jefferson, WI
Dec 14, 2007
  • Dec 14, 2007
May want to look at a stronger gearset to rebuild the t-5 with. At that point, you'll have tko500 money in a t-5 though. The upside is you won't need a different clutch, bellhousing, crossmember, etc. I love the way the t-5 shifts, so I'm going to do everything in my power to keep it, even if that means spending too much money on a performance gearset.
Sicarius428
2,085
Dec 14, 2007
  • Dec 14, 2007
With a turbo I believe they like a little resistance. The gear ratio from the TKO600 might be a better choice... that is if you are planning on getting a new transmission. For everything to install my TKO600 it costed me about 2500 to my door.
Kevin
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
  • dan50
  • Jul 18, 2026
dan50
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
