Is torque plate honing necessary for 4-500hp?
ryan7662
120
Hello again, is torque plate honing really a necessity for power levels between 4-500hp. Its my stock 351w I just rebuilt and since the motor was only ran for about 3 hours I just wanna slap a good set of hyp. pistons in. Was going to toss it in my 95, throw a 70-72mm turbo on and be done with it. Was thinking I could keep the stock heads, crank, and rods and swap the regular cast pistons out for the hyp. pistons. The block was bored and honed at a shop but I'm almost certain they didn't use torque plates. Could I just toss the hyp pistons in slap the turbo on the pretty much stock motor and have a happy reliable 4-500hp or would the block have to be honed again with torque plates?
The main point is to get the 95 running and save my money for my 84lx which is going to be twin turboed with a dart iron eagle block. But if theres nothing wrong if swapping out the pistons in a pretty much freshly rebuilt 351w I'd like to do that too.
my builder always uses torque plates because he says the pressure of the torqued down heads does change the shape of the cylinders and the you end up with a better seal which means more power. but he is one of those guys who is all about the details and that is why he still builds racing engines after 40 years. customers come to him wanting him to squeeze as much power as possible out of the engines he builds, and that is part of his approach
do you really NEED it done like that? no
would a serious racer want it done like that? yes
would no torque plates on the hone job be noticeable to a regular hack like me when driving around? no
So the headbolts, or studs, that apply pressure perpendicular to the deck of the block cause cylinders to distort that are also perpendicular to the deck of the block?
Just having a hard time imagining it. Sounds like a theory from trigonometry in highschool LOL. Show me some data that backs up these claims (not telling u literally). It could sound good on paper and not actually really do anything. How can you prove it? Dyno engines back to back? Leak down compression tests?
Seems like there are too many variables involved to prove it.
having had no real life experience with it, all i can do is report what i am told. and that is what my engine builder (his name is jan norris) told me. as i said, he has been building racing engines for 40+ years now. he also teaches automotive engineering courses at the university of maryland (college park). so i think it is safe to believe what he says.
I understand man. Im just simply saying with stuff like that, i'd love to be in one of his classes so i can say....prove it. Even a theory that makes sense doesnt always play out in real life. And an impressive resume thats 100 pages long doesnt mean i automatically believe u....it just means that u should be able to prove it to me even easier.
This slight cylinder distortion was found at the tops of the cylinder bores years ago. For street/passenger cars it's not really a big issue.
To eliminate this, the designers of the modular engines utilized the long head bolts to grab the block at the base of the cylinders. Motorcycles have been like this for years.
If I was building a 4 to 500 hp engine, I would. Thats just me.
GT
Look, if you want an indepth explanation, then look around on the internet. The fact that someone invented a "torque plate" to remedy the problem is proof enough for me. People generally don't create expensive inventions to fix problems that don't exist.
My engine wasn't done with torque plates, and it turned out just fine. I imagine if I was running a high power car in a tight class, I would probably do it.
Kurt
Kurt
Relax.:rolleyes: My point was i would want more than just words on paper or a monitor to see what is physically happening in the motor. The fact that something was invented doesnt mean squat. That simply means they could profit off of the idea.
Searching on the internet you could find crap to support either side of the argument. Which is also why i said i would enjoy to be in this guy's class so i could get up close and personal with his claims. Didnt know i wasnt allowed to think on my own :(
Or perhaps you could tune into the infomercials on tonight at 3am to see the many inventions that must work....since someone went through the trouble of inventing them :D
You've got a decent point. I talk with the chief engineer for John Force Racing occasionally, and he says they make a big difference on high power engines.
Kurt
ryan7662,
If it was me I would put in Forged instead Hypereutectic pistons since you are planning on boost.
And yes I would spend the $150 and have it honed with torque plate's held on by bolts or studs whatever you are using. (I would recommend getting head studs).
But you will probably be o.k. not doing anything I said. Just get your tune right and don't go lean and have detonation, that's what is going to give you problems.
I would be more worried about the Hyper pistons and that power levels! But you will build MORE Power with the cylinders trued with a deck plate when final hone is done!! Is it "Required" ?? Nope!! but that is why some cars are faster than others with the same engine components... attn to detail!! It is called indexing and Blueprinting!!
Just me.............................
Thumper
