Is used the way to go..?
  • Thread starter Thread starter clemsonf250
  • Start date Start date Mar 13, 2013
C
clemsonf250
Upstate SC
Mar 13, 2013
  • Mar 13, 2013
I found a deal on a 77mm Pro-M Mass air meter from a guy on craigslist. He's asking 125, i was gonna offer 100.
My question is, do MAF's normally go bad or tear up? Or am I getting a good deal here?
Let me know what you guys think..
MikeH686
Mine is only two inches though.
2,843
1,753
184
Waldorf, MD
Mar 13, 2013
  • Mar 13, 2013
Is it calibrated for the injectors you have in it? If not its gonna make your engine run poorly
Reactions: 88LX5.Oh
Bryan83taco
554
40
39
SF Bay
Mar 13, 2013
  • Mar 13, 2013
I would go for it. Go used when you can to save a buck. I don't think maf's are a wear & tear item.
C
clemsonf250
Upstate SC
Mar 13, 2013
  • Mar 13, 2013
Yeah its for 24's. It has the filter on the end of it too. So i should go for it?
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Mar 13, 2013
  • Mar 13, 2013
Here's an idea.
bring your car.
Reactions: 93project
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Mar 13, 2013
  • Mar 13, 2013
the 77 is an awesome meter that they stopped making years ago and replaced with an 80.
I personally think the calibration on those old 77's are better than anything else you can buy, period.
C
clemsonf250
Upstate SC
Mar 13, 2013
  • Mar 13, 2013
mikestang63 said:
Here's an idea.
bring your car.
That would be a great idea, if the car was already mass air. But its an 86 im converting to mass air to make sure the new motor i dont have in yet will run correctly.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Mar 13, 2013
  • Mar 13, 2013
Damn. Only other option to visually inspect it and take the guys word for it or see if he will hook it up to his car. Once you take it home, you own it. I don't know of any way to test it off a car. I think they will fix a broken one for about $100
http://www.promracing.com/
2000xp8
Aug 8, 2003
8,027
1,618
194
NJ
Mar 14, 2013
  • Mar 14, 2013
It's probably worth the risk.
Even if it is messed up, it can be recalibrated for another $100.
I agree 84top, the older pro ms were the best.
With that said, when converting to mass air, IMO, set your car up first with 19's and a stock meter (both should be dirt cheap or even free), then when you know it runs right swap in the 24's and new meter.
Reactions: 88LX5.Oh
88LX5.Oh
1,442
204
94
Arkansas
Mar 14, 2013
#10
  • Mar 14, 2013
  • #10
Very bad idea to build a motor then convert to MAF.
Very hard to diagnose issues that could come up from the MAF conversion itself or issues with the build.
C
clemsonf250
Upstate SC
Mar 15, 2013
#11
  • Mar 15, 2013
  • #11
will it not run like crap with speed density? cause all that stuff is still in the car, and its all working. The maf swap wouldnt be a big deal after i get the motor running. So i should start the new motor on speed density? Just so you know its not a stock motor. Its got a built bottom end with h/c/i. Will speed density still be the way to go?
Illuminator
10
29
So. Cal
Mar 15, 2013
#12
  • Mar 15, 2013
  • #12
Think mine is a Pro-M 77mm.....those are keepers eh?
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Mar 15, 2013
#13
  • Mar 15, 2013
  • #13
The 77 has an aluminum body and a filter that bolts on the end. If you have one, keep it!
88LX5.Oh
1,442
204
94
Arkansas
Mar 15, 2013
#14
  • Mar 15, 2013
  • #14
What me and 2000X8 were trying to say is if you're going to build a motor, a cheap MAF conversion should be the FIRST step in the process so you know you've done it all correctly.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Mar 15, 2013
#15
  • Mar 15, 2013
  • #15
Most of my engine is used. Only the carb, exhaust, water and oil pumps, flywheel and trans were bought new, everything else is "pre broken in".
C
clemsonf250
Upstate SC
Mar 16, 2013
#16
  • Mar 16, 2013
  • #16
i gotcha...
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
For Sale Ford 331 stroker engine for sale - with options!
  • TTSaleen
  • Jul 1, 2026
  • Engine and Power Adder
Engine and Power Adder Jul 2, 2026
