Issues with Holley 600 on 67 with 289 engine
maestro1024
This car sat for about 15 years and a couple months ago we started getting it back in shape. It runs now but the carb is still not right.
It was re-built by my friend (not a professional mechanic) and clean out with carb cleaner and we put new gaskets and such in there.
The problem is if the car sits say overnight it will not start. If we pull the front piece off the carb and clean it out it works. We had a float on the front section that was sticking too. We ended up putting the old one back on.
If you get the car going (pull front piece off or knock the float down) it will run great. And after it is warm it starts right up.
This car had an autolite 4100 or 4300 on it and this Holley is off a different mustang (which has also sat for a while) but it should be fine right?
Any ideas on getting the carb working better? Any other ideas for the car/carb to work around this situation?
Sounds like the needle is sticking in the seat...I would make sure he took the needle and seat out when he cleaned it...probably go ahead and put a new one in there since they arent very expensive. Those holley's are very tempermental, but once they are working properly and set they are great.
The needle was definitely sticking. We had a brand new one and the old one and the both stuck. Do I need to go by a 3rd one (maybe one in rebuild kit is bad or got messed up)?
Where can you pick up just this needle?
If the needle is bad or messed up why does it work after you get the vehicle running? Seems like once the vehicle has run and the engine is warm and all the thing works great.
Make sure the part that the needle and seat screws down into is spotlessly clean...also you may want to swap floats...put the one that was on the back on the front, might be an issue with your float. Have you properly adjusted your float? Sounds like you may need to raise it up a bit.
