IST Air Adjuster
  • Thread starter Thread starter KDK1988GT
  • Start date Start date Mar 30, 2004
KDK1988GT
1,937
Fredericton
Mar 30, 2004
  • Mar 30, 2004
Just wondering if anyone has used an IST air adjuster thanks
A
autoXr1
1,838
Michigan
Mar 30, 2004
  • Mar 30, 2004
Had one, used one, threw it out. It is used for fine tuning, unlike the Pro-M model. You have to have some form of air/fuel ratio meter to use it correctly. It DOES NOT like moisture and WILL shut your car down. You end up pulling it out of line to start the car again.
That said, it does what it is supposed to...alter the voltage signal off of the mass air meter, and does produce noticable changes in air/fuel ratio at idle. However, that's about where it's usefullness ends. In the end, it "confused" my computer enough that my engine would run differently every time I ran it...very inconsistent.
Just me...
04sleeper
2,674
14
89
Dallas, TX
Mar 30, 2004
  • Mar 30, 2004
I have used one on a friends car with similar results to autoXr1. I did not like how it worked with the computer.
KDK1988GT
1,937
Fredericton
Mar 30, 2004
  • Mar 30, 2004
so would you say that the Pro-M model would be a better one to go with? I hear that they have been improved. I want it so I can run a set of 30's or 24's (injectors) with my MAF thats been used with with stock 19's
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
