It's Alive!!!!
  • Thread starter Thread starter nick6690
  • Start date Start date Feb 5, 2009
nick6690
147
McDonough, GA
Feb 5, 2009
  • Feb 5, 2009
I started up my car today for the first time!!! The reason I started a new thread is because I wanted my question to get a little more attention. I'm not sure if this belongs in tech or not so sorry if its in the wrong spot. My progress thread is here http://forums.stangnet.com/769520-started-engine-rebuild.html
It sounds amazing except for a couple things need to be fixed. The back 2 cylinders on the passenger side are running really lean. The headers were glowing red after running a little over 5 min and the exhaust was popping really bad when it revved up. Could the injectors be stuck? I bought them used and they looked kinda dirty. After I started it back up after running it for the first time it was flooded and there was raw fuel coming out of the exhaust. What can I do to the injectors? Any help is appreciated.
All I have left to do to it is get the injectors fixed and some other small things. I have to put a vacuum fitting in the intake for the brakes and adjust the clutch and thats pretty much it and it should be on the road soon. I'll get a sound clip of the exhaust soon for yall to hear it, it sounds amazing.
nick6690
147
McDonough, GA
Feb 6, 2009
  • Feb 6, 2009
does anybody know what the problem is with the injectors? thanks
1991notchbackLX
1,483
47
48
New York
Feb 6, 2009
  • Feb 6, 2009
okay i'll give it a shot...
if you bought the fuel injectors used did you check the o-rings and pintle caps? the o-rings can be split or dry-rotted and the pintle caps have very fine screens in them that can be clogged, restricting fuel flow or just screwing things up in general... if i were you i'd pull them and check them out, a rebuild kit for them can be found online or possibly from a Ford dealership for relatively cheap (as in cheaper than a new set of injectors), good luck man
Chris
cenok is family
1,409
69
79
Norman, Ok
Feb 6, 2009
  • Feb 6, 2009
the pintle caps don't have screens in them but there is a filter basket on the top end of the injectors. they might be gummed up inside, before you pull anything, trying running a concentrated amount of b12 chemtool or something similar in your gas.
1991notchbackLX
1,483
47
48
New York
Feb 6, 2009
  • Feb 6, 2009
ooh i thought the little caps on the end with the four holes and the screens were called the pintle caps, i guess my terminology is screwed up, but yeah to the OP, listen to cenok lol
Strippt88
81
Cedar Lake, Indiana
Feb 6, 2009
  • Feb 6, 2009
Yeah, try cleaning them before you take 'em back out- and, if you take 'em back out, throw them in the trash, and get new, proper ones that won't risk your newly finished motor
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
M
Running rough
  • Mike3
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 1, 2026
Mike3
M
  • brandyn200
  • Jun 20, 2026
AeroCoupe
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
