  • SN95 4.6L Mustang Tech
Its fluid time...HELP?!
  • Thread starter Thread starter SilverBullet00
  • Start date Start date Nov 11, 2004
SilverBullet00
1,150
Wichita, KS
Nov 11, 2004
  • Nov 11, 2004
I have searched over many posts and have been doing some research on trans. and rear end fluid. I have come to the conclusion of using Royal Purple Syncromax in the tranny, but I still dont know about the rear end. I have found it unclear if running synthetic is bad and if you need an additive or not for the limited slip. So what should I look for??? My stang is my daily driver so I want performance with longevity. I know many of you have different opinions on what to run, but I am mostly after the "this will wreck your rear end if you..." help. thanks a lot guys!
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Nov 11, 2004
  • Nov 11, 2004
use a synthetic diff lube, Mobil 1, Redline, and RP are all good. i do not believe you need the additive with most of the synthetics.
SilverBullet00
1,150
Wichita, KS
Nov 11, 2004
  • Nov 11, 2004
anyone else want to through in the .02?
Fast02
239
  • Nov 11, 2004
Believe it comes factory with Synthetic in the rear end diff. I also would think as long as its one of the brands mentioned above and amsoil....that the next questions should be price and availability.
40th GT
916
Lawrenceville, GA
Nov 11, 2004
  • Nov 11, 2004
Is it necessary to change the diff. fluid on a regular basis? I would guess so since it protects moving parts. But the manual says it's supposed to last a lifetime..
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
L
5.4 4v base ignition timing table help.
  • leoleo
  • Aug 16, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 17, 2026
MustangBetts
M
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
