its...its impossible...
  • Thread starter Thread starter 89GtConvert5spd
  • Start date Start date Sep 22, 2005
89GtConvert5spd
58
  • Sep 22, 2005
Alright i posted before about missing on a cylinder...and so i put everything back togeather...started it up, it idles...so i pull a plug wire off....no difference...long story short...i pulled off 6 plug wires...at once...i left only the 1 and 5 on...its idleing on 2 cylinders....its reving up and everything...i mean i pulled the wires off the dristibutor and everything...what the hell...how do i solve this one? if anyone can figure this one out your a god ...everyone i asked said it is impossible to run a v8 on 2 cylinders... :damnit:
replaced distributor,wires,plugs,car,rotor, and put a timing liught on it...where do i go next...please help me i miss my ride!!!
shttygtstang
978
  • Sep 22, 2005
you have a v twin cool
89GtConvert5spd
58
  • Sep 22, 2005
lol more like a wussy GEO
N
Na5.0HO
342
Michigan
Sep 22, 2005
  • Sep 22, 2005
Maybe.... your using a high octane fuel... and you have alot of residue on top of your piston which is causing excessive compression and forcing your car to 'diesel'!
See, that was easy!
89GtConvert5spd
58
  • Sep 22, 2005
that cant be i use nothing but pump gas...
HISSIN50
34
129
Sep 22, 2005
  • Sep 22, 2005
Dieseling normally requires a glowing plug or glowing carbon build up, which requires a hot ignition to get to that point in the first place (why dieseling often happens only on hot motors).
If the cylinder is not firing, it does not get all that hot (relatively speaking).
shttygtstang
978
  • Sep 22, 2005
spark jumping from cylinder to cylinder?
89GtConvert5spd
58
  • Sep 22, 2005
so are you saying im not getting a hot enough spark?? cuz i pulled out the plugs and they all had a nice purple spark...and it happens when its cold or hot...they just dont fire period..
HISSIN50
34
129
Sep 22, 2005
  • Sep 22, 2005
I cant see how a motor can idle purely on two cylinders, but.....
Have you done a cylinder balance test? It is part of the self diagnostics and since the car idles, you can do it. It will confirm which cylinders are not helping (not doing anything).
If you have spark, are you sure you have injector pulsing on the bad cylinders? A noid light can be used to verify that you have a juice making it to each injector (12 volts is key-on constant, and the puter pulses the ground to each injector).
Go from there.
Good luck.
89GtConvert5spd
58
#10
  • Sep 22, 2005
  • #10
alrightg ill give that a shot...yea its only running on the 1 and 5...everyone says its impossible...i should take a video clip...
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
  • brandyn200
  • Jun 20, 2026
AeroCoupe
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
