It's this necesary
Hi guys
I recently have been experiencing some trouble whit my 96 vert
For example when I go over a speed bump or when I’m on uneven pavement
I begin to hear a lot of noise on the front and on the rear of the car
So my conclusion is that since is a 10 year old car probably mi control arm bushings are shot so I went and order the complete set of bushings from energy suspension
So my question is since I’m getting down there should I replace my lower ball joints and inner and outer tie rod ends since it’s going to need alignment
if you got the cash go ahead but while down there make sure you need them even though noise reduction a bonus you sacrifice your smooth ride for stiffer unless you leave the bump stop bushing as stock to kepp it comfortable and it could also be your your tires i ride protenza's run flat with thick side walss and even stock suspension my ride get bumpy
