I've been Terminated
Those are 18 inch wheels correct? Very good choice! Only other choice for me would be a silver or Oxford White one!
Yea they are 10in replicas. 18x9 in the front and 18x10.5 in the back. I'm in love with the color. Pictures don't do it justice. Right now the back tires are 335 nitto 555 DRs. The tires need replacing. Does anyone know how a 335 street tire looks on a 10.5 inch rim? I heard the nittos run narrow. On my 98 a had 315 555s and they looked pretty good. I want to go as wide as possible though.
Here is a list of the mods it has on it. I plan on doing the boost overlay mod and HID's. That's really about it.
• Ported Eaton
• 2.76” upper pulley
• 2lb lower pulley
• Metco billet idler pulley set
• 60lb injectors
• Kenne Bell Boost-A-Pump
• PPRV delete kit
• MAF
• SCT BA2400
• Accufab single blade throttle body
• Off-road x-pipe (no brand name on it)
• Magnaflow catback
• SPEC Stage 3 clutch
• Aluminum flywheel
• 26-spline input shaft
• Hurst short-throw shifter
• Clutch quadrant / firewall adjuster
• Full length subframe connectors
• Drilled and slotted rotors
• Aftermarket heat exchanger (no brand name on it).
• MM Caster Camber Plates
• Eibach pro springs
• Yellow-top Duralast Gold Battery
• Tuned by Justin @ VMP. Dyno’d at 487rwhp/485rwtq on a 90 degree day. SCT XCAL2 included.
