  • 1994 - 1995 Specific Tech
I've lost my head...
  • Thread starter Thread starter HoofnIt
  • Start date Start date Jun 23, 2004
HoofnIt
1,175
North Carolina
Jun 23, 2004
  • Jun 23, 2004
...well both of them to be exact. I have removed both cylinder heads and exposed 8 carbon-coated pistons. Should I try to clean some of the carbon off of the pistons before installing my new heads? I know carbon build-up can contribute to detonation, so cleaning them up would be a good thing. Did you guys clean yours and if so, what did you use. THX
5.0_GT_kid
20+ Year Stangneter
Apr 18, 2004
1,155
Largo, Florida
Jun 23, 2004
  • Jun 23, 2004
Doesn't GM Top Engine cleaner and/or Seafoam clean carbon outta there?
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Jun 23, 2004
  • Jun 23, 2004
When I owned my 72' Duster and rebuilt the engine I clead the carbon off the pistons by using liquid carb cleaner I let them saok for a little than wire brushed them clean worked just fine.
HoofnIt
1,175
North Carolina
Jun 23, 2004
  • Jun 23, 2004
Cleaning them off shouldn't hurt anything, should it? I just hate to put brand new AFR heads over those nasty looking pistons.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Jun 23, 2004
  • Jun 23, 2004
It will not hurt you at all it will only help you performance wise. If I was about to put new heads on my car there is no way I would leave my pistons covered in carbon crap.
Joes95GT
3,132
Delaware
Jun 23, 2004
  • Jun 23, 2004
The only bad thing about top-end cleaner is that it smokes like a mofo.
I'd be really careful taking any kind of harsh abrasive to a cast piston. I wouldn't like scraping **** off of the pistons unless I had a vacuum right behind me...
Joe
HoofnIt
1,175
North Carolina
Jun 23, 2004
  • Jun 23, 2004
Well, right or wrong, I did manage to get the majority of the carbon build-up off. It took a lot of effort and I did use a shop vac. I also made sure that each piston was at TDC; after it was clean, I rotated the crank and cleaned the walls again. I repeated this process twice. Now, since the cylinders are wiped free of oil, would it be a good idea to coat the walls with a little motor oil before slapping the heads on?
GTJake
3,049
Ann Arbor, MI
Jun 23, 2004
  • Jun 23, 2004
Yea, put a little oil on the walls before you put the heads on.
Jake
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
gkomo
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
