J&M Products : Forum Sponsor : Updates
J&M Products
Premium Sponsor
Jan 22, 2007
62
10
29
Paso Robles
J&M Products would like to take this opportunity to inform everybody we have decided to sponsor and help support stangnet.com. We feel it is very important to support forums which help the general public in the way stangnet.com does. We have also decided to specifically sponsor the 4.6L forums and would be willing to help answer any suspension related technical questions you have. We are available by phone, email, or pm so please does not hesitate to ask.
Newest Product Release
Fits: 1994-2004 Ford Mustangs
Camber/Caster Plates:
Do you need to take control of your Mustangs front suspension? You can do it by using a set of J&M Products adjustable caster and camber plates. J&M plates replace the stock rubber strut mount bushings with a chrome-moly spherical bearing, allowing you full control of the front suspension alignment. Whether you want your alignment set for track, street, or strip, these plates will allow you to fine tune your alignment so you can get the most out of your car. The bearing mounts are completely adjustable and are 100% high frequency pulse welded for the ultimate in strength, durability, and fit. These camber/caster plates also feature a special chrome moly replaceable Teflon lined spherical bearing for a noise free quality ride. J&M Camber/Caster plates are now coming with a LIFETIME WARRANTY which covers bearing failure, main plate bending, or just over abuse. That is right if you are the original owner and bend the plates or wear out the bearings they will be fixed or replaced for free. That is how confident we are that you are purchasing the best camber plates available.
J&M Products plates include the following features:
-LIFETIME GUARANTEE against bearing failure and main plate bending or breaking.
-Slots for adjusting caster and camber independently from each other.
-Easy adjustment for Street and Race applications without the need for taking apart and rotating the camber plate.
-Replaceable highest strength chrome moly Teflon-lined spherical bearings for noise free performance.
-Greatest increase in suspension travel for lowered cars.
-Powder coated for great looks and long lasting protection.
-4 bolt option for the 94-04 Mustangs vehicles for coil-over use.
-Alloy steel main support plate for ultimate strength.
-Press in studs allow for more suspension travel clearance on coil-over applications over any other design available.
-Bearings and bearing mounts are loaded and supported from the bottom to remove the load from the hardware.
Glad to have you....its always good to have vendors that can answer customer questions directly :nice: .
Do you guys have any plans to give some sort of discount to SN members? Im not much of a suspension guy, but there are alot here...im sure that would help your sales ALOT. Makes people feel special I suppose haha.
We have to walk a fine line with discounts. As a manufacture we ethically have an obligation to support our dealers and under cutting them with our own suspension parts is not something we will do. Now for non J&M Products parts we would be happy to offer discounts when possible to stangnet members. You will need to email, PM, or telephone us for pricing.
Ahh, I understand. I was asking this on everyone elses part, and to hopefully help you guys out.....not for myself BTW. I dont have any money to buy anything anyways :D.
Again, best of luck to you and enjoy your stay!
OEM Fit Stainless Steel Brake Hoses
J&M Products is proud to announce the release of these new direct fit D.O.T. certified Teflon lined brake hoses. These brake hose assemblies use true OEM style direct replacement non-universal fittings to achieve proper factory hose routing and fitment. Expansion of stock rubber hoses causes a spongy brake pedal feel and loss of initial braking force. Installation of our Teflon-lined stainless steel hose assemblies will give your car a firmer pedal, quicker braking response, and easier brake modulation. Every hose is tested to 3000 psi to guarantee a leak free hose assembly. Best of all these are made by J&M Products right here in the USA.
Benefits:
- Direct OEM fit
- Quicker brake response
- Better brake modulation
- Every hose is pressure tested to 3000 psi.
Rear hoses and 94-98 hoses in engineering and soon to be released. To order visit www.hotpart.com
We have finally come out with our new DOT legal direct replacement stainless steel Teflon lined brake hoses for the rear of the 94-04 Mustangs. They can be ordered online at www.hotpart.com or through one of our dealers.
These are the only true DOT legal Stainless Teflon Lined brake hoses on the market that mount exactly like the factory hoses.
