J&M Products is proud to release our completely redesigned fully adjustable PATENT PENDING Camber & Caster plate assembly for the 2011-up Ford Mustangs. This Camber/Caster kits is the only kit that comes complete READY to bolt in right out of the box (no need to swap anything over from the factory mount). Whether you are using the car for street, autocross, road racing or drag racing these plates are designed for you. These are the only plates that have an offset design allowing for you to install them in the street orientation or a race orientation allowing for the most camber adjustment available compared to any other plate on the market. Just like our other Camber/Caster plates these come with a full lifetime warranty to the original purchaser of the product.
Benefits:
- Allows for camber and caster adjustment not available from the factory
- Allows you to align your Mustang back to factory specifications even when lowered
- Camber & caster are adjustable separately.
- Offset design allows for either street use or race use alignments.
- Provides for caster adjustment not found on the factory mounts
- Caster adjustment to allow correction for OEM production tolerances.
- Alignment is easily adjusted at the top of the strut tower.
- Spherical bearing eliminates un-wanted deflection and precisely locates the strut shaft during cornering.
- Completely assembled and bolts in with no need for extra drilling or cutting.
- ONLY kit that includes everything needed to install all the way down to the rubber spring isolator.
- Unlike competitors you don’t need to remove parts from the factory mount and install on our mount.
- Over 2.5 degrees of camber adjustment, adjustable without affecting caster.
- 0.7 degrees of range of caster adjustment.
- Teflon lined spherical bearing manufactured in the USA.
- All parts are either plated or powder coated for great looks and long lasting protection.
- US Patent Pending.
- Lifetime warranty on the entire camber plate to the original owner.
