Yesterday I finally got around to installing my new J&M LCA's, adjustable upper, adjustable panhard bar and Steeda relocation brackets. My buddy has this same set up and Bigcat had recommended it to me more than a year ago.
My first impressions are how extremely quiet the J&M design is. Absolutely no additional NVH whatsoever. Their bushing design really is tops. The ass end of the car is very predictable now and solid. One major improvement is the fact that I can do a burnout with such control even with the tires barely spinning...no wheel hop or vibration at all.
I've got the pinion angle at -2 degrees, I welded the Steeda brackets in which it's a good idea to note that before welding in relocation brackets it's extremely important to ensure that your front to rear wheelbase is measured before any work begins and that measurement must be matched before you weld them up solid. It's very easy to screw this up causing one LCA to be set at a different angle than the other and your rear wheels will not track straight and in proportion to the front end of the car.
I highly recommend the J&M Products suspension offerings. Very pleased!
my personal opinion is that i will not use or recommend any other manufacturer. J&M is top notch and service is awesome. i have even been given cell phone numbers of employees there, just in case there is ever an issue. that is service at its finest.
