  • SN95 4.6L Mustang Tech
J-MOD + TRANSGO SHIFT KIT??
  • Thread starter Thread starter 97gtconv.
  • Start date Start date Dec 22, 2004
97gtconv.
244
Lock Haven, PA
Dec 22, 2004
  • Dec 22, 2004
I'M GETTING READY TO DO THE J-MOD TO MY STANG AND I WAS WONDERING IF IT'S POSSIBLE TO DO THE J-MOD AND THEN DO THE TRANSGO SHIFT KIT??JUST CURIOUS, THANKS
K
kuma
39
Hawaii
Dec 22, 2004
  • Dec 22, 2004
Why would you want to do the Transgo after the J-mod? The J-mod will firm up the shifts and is safer than the transgo.
kuma
R
Rocketman
730
SoCal
Dec 22, 2004
  • Dec 22, 2004
Its the same mod. Only difference is the J-Mod is free.
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Dec 22, 2004
  • Dec 22, 2004
Do the J-Mod instead!
Y
YtnGT
202
TX
Dec 22, 2004
  • Dec 22, 2004
One or the other.
triggz
1,218
Gadsden, AL
Dec 22, 2004
  • Dec 22, 2004
The j-mod is modifying the stock seperator plate
Trans-go is replacing the seperator plate..
That would be like putting in super-white headlight bulbs, then switching to HIDs.
I suggest j-mod.
However, you can add an 'electric' shift kit afterwards. One of the gizmos that boosts the EPC solenoid pressure in the transmission.. These are a little safer once you have a good seperator plate.
(quick lesson:
seperator plate/valve body modifications open the path for fluid to flow wider without increasing trans pressure
electric shift kits force the fluid through the openings with higher pressure but are harsh on the trans)
D
AOD with 4R70W Internals and a Shift Kit - 1 to 2 Shift Question
  • Davjake128
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
Davjake128
D
Fox Rear Seat Belts - 87-89 vs 90-93 length
  • dan50
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
Mustang5L5
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
wyatt-tetro891
W
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
