Jack Recommendations for a Lowered Stang?
  • Thread starter Thread starter 007
  • Start date Start date Jun 23, 2010
3,287
24
69
Broke
Jun 23, 2010
  • Jun 23, 2010
My car is lowered two inches and has FLSCs under there too. I'm looking for a good low-profile jack without breaking the bank. Any recommendations?
Also can you jack the car up on the subframe connectors or is that a bad idea?
3ponyshow
319
Las Vegas
Jun 23, 2010
  • Jun 23, 2010
Harbor Freight.
It's a very good idea, but you'll need a low profile jack to reach them. Until then, for the front, you can use the ground effects seam (cringe) about 7" in behind the front tire, or under the control arm. Then you can get a larger lift in to your sub frames or K-member, depending on what you're doing. I only use either of those to get to the sub frames.
Rear is much easier. Just in front of the rear tire about 12" in. No low profile required.
N8Dogg98
3,872
238
184
MN
Jun 23, 2010
  • Jun 23, 2010
Build yourself a ramp with 2x6's it's what I did and it works perfectly. Drive on teh ramps, then get the jack under the K member.
stprorolla49
1,455
15
39
Fairfield, CT/North Jersey
Jun 23, 2010
  • Jun 23, 2010
x2, works like a charm.
BurningRubber
1,865
24
58
Jun 24, 2010
  • Jun 24, 2010
Pick up a Car and Driver, look towards the last few pages of the magazine and there should be a page full of Harbor Freight coupons.
I got a 3000lb (not a lot, I know) low profile, light weight aluminum racing jack for $70 I believe with that coupon. So far so good, and they offer a 2 year replacement guarantee if I remember correctly.
My GT isn't as low as yours, but I still had a little room to spare. Hopefully it would work for your car as well.
3,287
24
69
Broke
Jun 24, 2010
  • Jun 24, 2010
Thanks for the recommendation of habor freight. They have a great selection.
This one?
3000 Lb. Capacity Lightweight Aluminum Racing Jack
Or this one?
Rapid Pump® 3000 Lb. Capacity Lightweight Aluminum Racing Jack, Blue
Think I'm going to buy this one - slightly higher rating, and a lower min height.
2 Ton Low Profile Floor Service Jack
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 24, 2010
  • Jun 24, 2010
I got mine at Harbor Freight for $179 and it is very nice. I have had it for a year, no problems so far.
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
