Jack Recommendations for a Lowered Stang?
007
3,287
24
69
Broke
My car is lowered two inches and has FLSCs under there too. I'm looking for a good low-profile jack without breaking the bank. Any recommendations?:nice:
Also can you jack the car up on the subframe connectors or is that a bad idea?
Harbor Freight. :)
It's a very good idea, but you'll need a low profile jack to reach them. Until then, for the front, you can use the ground effects seam (cringe) about 7" in behind the front tire, or under the control arm. Then you can get a larger lift in to your sub frames or K-member, depending on what you're doing. I only use either of those to get to the sub frames.
Rear is much easier. Just in front of the rear tire about 12" in. No low profile required.
Pick up a Car and Driver, look towards the last few pages of the magazine and there should be a page full of Harbor Freight coupons.
I got a 3000lb (not a lot, I know) low profile, light weight aluminum racing jack for $70 I believe with that coupon. So far so good, and they offer a 2 year replacement guarantee if I remember correctly.
My GT isn't as low as yours, but I still had a little room to spare. Hopefully it would work for your car as well.
Thanks for the recommendation of habor freight. They have a great selection.
This one?
3000 Lb. Capacity Lightweight Aluminum Racing Jack
Or this one?
Rapid Pump® 3000 Lb. Capacity Lightweight Aluminum Racing Jack, Blue
Think I'm going to buy this one - slightly higher rating, and a lower min height.
2 Ton Low Profile Floor Service Jack
