  • SN95 4.6L Mustang Tech
Jacking car question
  • Thread starter Thread starter mac9898
  • Start date Start date Jun 11, 2004
M
mac9898
70
Minneapolis
Jun 11, 2004
  • Jun 11, 2004
I am installing a cat back on my 99GT
I have searched this forum for the correct
areas to jack up the rear end.
I have seem the diagrams, but I have a rear trailing arm
in the way of me getting the jack on each side of the
rear axle. Is there a better spot? Can I jack in the rear diff,
just to get the jack stands under it?
Thanks!
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Jun 11, 2004
  • Jun 11, 2004
There should be two areas you can reach from the sides without having to go around the rear axle to jack it up. It's a little hard to describe but if you know where the side scoops are on the car, it should be just under them on the under side of the car.
You can try jacking it up by the rear diff. even though the instruction manual from Ford tells you not to. I've done this once myself and I've seen some other guy do it on my car at a garage without problems.
troyGT03
278
too close to memphis,tn
Jun 11, 2004
  • Jun 11, 2004
check bullitarchive.com and click on maintence. and yes it is okay to put a juck under the diff
Str8Pimp'n
492
Str8 outta Compton...
Jun 11, 2004
  • Jun 11, 2004
put the jack under the shock mounting point and lift up each side there. Put your jack stands on each side of the axle tube. Don't get under the car with just one jack under the center diff.
G
GinoGT
1,862
Jun 11, 2004
  • Jun 11, 2004
Put the jack under the differential housing and lift away. Manuals will tell you not to do it, but people have been doing it for decades without any problems.
chini42
138
Brownstown, Michigan
Jun 11, 2004
  • Jun 11, 2004
http://www.bullittarchive.com/Maintenance/jacking/
ImportEater98
708
Worcester, MA
Jun 11, 2004
  • Jun 11, 2004
Im with GinoGT. I always jack up under the pumpkin. Then i put jackstands on either side of it for stability. Easier to jack up the back than the front in these cars.
I
inferno9898
249
Jun 12, 2004
  • Jun 12, 2004
if you jack up by the diff, make sure u put the jack under the actual pumpkin, and not just the differential cover.
KaPPaBaLL
1,326
BAYAREA
Jun 12, 2004
  • Jun 12, 2004
make sure you do it when it's dark and peeps aren't watching... shh
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Jun 12, 2004
#10
  • Jun 12, 2004
  • #10
Your mom called me this morning and said tonight, she and I should do the same thing ?
KaPPaBaLL
1,326
BAYAREA
Jun 12, 2004
#11
  • Jun 12, 2004
  • #11
that's just nasty and i doubt you'd go through with it..
C
CottonBurnerz
Banned
May 10, 2003
1,554
Drink and Drive = Teh Lose
Jun 12, 2004
#12
  • Jun 12, 2004
  • #12
lol wtf? anyhow, I did mine on a ramp with 2 jack stands at the front side of the car.. There should be a thingy on the side of the car on 4 spots for you to jack the car up with hand jacks.. good luck
Firemanz
Only you can prevent Forest Fires!
4,105
San Antonio, TX
Jun 12, 2004
#13
  • Jun 12, 2004
  • #13
Yep. I have to jack my Roush up like that when I change the oil or clean the bottom of it. Always use jack stands......
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
Jacking up driver side
  • Scrapla347
  • Sep 28, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 26, 2024
CassieL
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
