  • SN95 4.6L Mustang Tech
Jacking points
  • Thread starter Thread starter COramprat
  • Start date Start date May 30, 2004
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
May 30, 2004
  • May 30, 2004
Found this over on the Depot. I have seen this question quite often and also complaints about bending your sheet metel.
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
May 30, 2004
  • May 30, 2004
i just jack my stang up on the frame rails. I place a piece of a 2x4 between the jack and the frame though. i make sure the piece of wood is going the same way as the frame rail so it dispurses the weight of the car off that single point where the jack is. this keeps it from crusing the frame rail
00BlackBeautyGT
298
E.S. Long Beach, CA
May 30, 2004
  • May 30, 2004
I messed my underbody pretty bad when I was jacking it up. I thought it was okay to jack it at the spot. Turns out that the particular spot was very soft. I bent it up pretty bad. Never forgave myself for it.
Defleshed
Satanic Mechanic
Nov 30, 2003
10,569
In Torment, In Hell
May 30, 2004
  • May 30, 2004
that 2x4 is a great idea. i need to do that from now on, so i stop denting things.
4.6_02_Black_GT
622
Charlotte NC
May 30, 2004
  • May 30, 2004
I agree with everyone, the K member jacking point is good, but I too have noticed mines starting to get dented up cause my floor jack has those little tabs on the nose that seem to bend the metal. Also I have noticed my jack stands bend are denting the frame rails too. I have always place the stands at exactly the same spots and the frame rails have corresponding dents in them.
I think the 2x4 idea is good...just be careful, wood can be slippery.
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
  • Gulftown980x
  • Jul 29, 2026
squeak93
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
Buying with a bad motor?
  • djj62478
  • Mar 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 11, 2026
TTSaleen
What Movie Would You Make?
  • Noobz347
  • Oct 9, 2026
  • Off-Topic Hangout
Off-Topic Hangout Oct 14, 2026
DadLife0724
