Have you tried to losen all the mounts (allso the transmission mount) and move the engine a little to the passenger side and then force it to the rear when tighten the bolts in the mounts? Still needing more space you could try some thick washers between the engine mounts and the engine block to raise it a little. Or enlarge some of the holes in the mounts, so the engine and gearbox can move just a little more rearwards. Maybe moving the engine 1/8" to the passenger side and 1/4" to the rear is all you need.![]()
Pushing the engine to the passenger side wont' work for a couple of reasons.
First of all, We have to push the transmission a bit to the driver side to get it in the T5 crossmember. Also, there isn't really any movement available in the motor mounts. The mount has to sit inside the frame brackets and there is a tab on the inside edge of the frame brackets.
Secondly, The engine is nearly centered in the car already. Since the driver and passenger side headers are not mirror images of eachother that is where the problem comes in I think.
