Well first off, Happy Thanksgiving to all of you. Mine's not starting off so great.
Some backround:
On my way home from my girlfriend's tonight, I was on the highway, and i felt my car start to shutter a little..... then it kept getting stronger.... almost like it was low on gas (I have more than a 1/4 tank). Then the RPMs kept going down. It finally died. I pulled over and tried starting it back up. Took a couple times, then it started.
It died a few more times, so I drove all the way home on the shoulder. It has a VERY rough idle now, and if you give it any gas it stalls, and wants to die. But if you get it up above about 1200-1500 RPMs it seems like It'll stay. I can let it sit at 2000-3000 RPM without any problem. it just wont idle, or do anything when you give it any throttle. It keeps dieing.
What could this be?!?!?! Fuel pump, fuel filter, plugs, wires, cap, rotor, throttle position sensor????
If ANYONE can help, it would be GREAT because its snowy up here any my stang doesn't do too well in the snow. I need my 4WD.
Thanks guys!
-Shaun
Some backround:
Thanks guys!
-Shaun
