Jeep Speedo Gear? Really?
'88Cobra
46
So my car has 3.55 gears in the rearend, and my speedo is out. After doing a search I found that I need the 23 tooth white speedo gear that is apparently a jeep speedo gear in my tranny. But the info I didn't find is what jeep speedo gear do I need? Meaning what year of jeep? What model? And what tranny did it come out of? Any help please?
Oh, sorry. I am totally leaving info out. The T5 is for a '90 GT, not an '88. So it should have an 8 tooth drive gear. And the rear gears are 3.55's, and the rear tires are about 26.5" tall. So a 23 tooth gear should be right, shouldn't it?
A 1990 tranny does change things.
# Driven Gear Teeth = 20.168114 / Tire Height (in.) * Axle Ratio * # Drive Gear Teeth
20.186114 / 26.5 * 3.55 * 8 = 21.6
A 21-tooth gear should get you to within a 3% speedometer error (discounting other factors), which is pretty good.
Visually confirm your drive gear though. Being a 1990 t-5, it's had 18 years of history and someone could have changed the gear. A lot of guys tend to swap to the 7-tooth gear
Take the speedo and look inside. If it's yellow, it's the 7-tooth
if it's green----8 tooth
If it's black....6 tooth
