jerking at low RPMS...
genericstang
120
Marietta. GA
today when i was out driving and slowing down my 88 5.0 (5spd) it started jerking. i was in second and starting to come to a stop. it doesnt do it in any other gear except a little bit in 3rd. and it only does it when slowing down.
i also noticed that it almost feels like the throttle is getting stuck when im accelerating. i dont think its the clutch slipping,(doesnt feel like it at least) its like a "hesitation" after depressing the accelerator.
it has not done this before ever. anyone have any ideas? :shrug:
are you serious? low rpm's with the car still in gear coming to a stop will ALWAYS result in bucking/jerking. why even downshift when coming to a stop? just put the car in neutral. car was going to slow to be in that gear. bucking/jerking when coming to a stop will result in stalling out if you dont put your foot in on the clutch. common sense.
correct me if i misunderstood what you originally said.
no, i think i confused everyone. i know it will buck and jerk if im slowing down in low gear etc. let me see if i can explain this better.
ok lets see here...
for example i was going through the parking lot at about 2K RPM and in second gear and just on the gas a little and it jerks like crazy. and thats never happend before at all.
also in addition to what i posted above, when i first turn on the car on now the RPMs fluctuate from like 550-1000 like 4-5 times then settles out at normal RPM range(around 800 or so, give or take some). this is starting to frustrate me.
anyone have any idea now? :(
Stang8URMPRT said:
If you MUST jerk it in your car... I guess doing it at low RPMs is best? :shrug: :rlaugh:
i knew this was cumming. :lol: ANYWAYS...
ill check the codes. i got a buddy with a reader. i thought maybe it could be the alternator(dont know if its ever been replaced/serviced in the 132K miles that are on the car). i will also check out the fuel filter, i dont think that has been changed either. anyways, thanks for the helping everyone.
keep the posts coming :nice:
so its either, the...
-Idle Air Control Valve
-Throttle Position Sensor
or possibly, the PCV (i dont think it has been changed either). i think ill start with this and then work with the others if this doesnt work.
thanks again for everyone's continued help.
