Jerking Car, electrical problem...
  • Thread starter Thread starter wild70stang
  • Start date Start date Dec 9, 2007
wild70stang
317
  • Dec 9, 2007
Jerking Car, Culprit FOUND!
My car is having some wierd problems and I tried to research this on google and using the search button on this site, but had no luck. When I was driving yesterday at around 70mph the car was "jerking" which felt like the throttle had been let up really quickly and then returned to normal (if you dont get that it felt like the car was being pulled backwards). I even traveled at speeds of 65 and 60 and it still did this. So I figure its something to do with the timing or the electrical. My distributor has the electronic ignition, I have a new alternator, new battery, new ignition coil, and new ignition switch. Any help is appreciated to solve this mystery. THANKS
rbohm
6,698
550
204
tucson,az
Dec 9, 2007
  • Dec 9, 2007
remember that the entire electrical system goes through the starter solenoid, so if it is going bad, that can cause the exact problem you have. also make sure you have enough fuel pressure at speed as well.
N
nugget68
362
  • Dec 10, 2007
sounds more like a suspension issue to me...i have a similar issue with my 68 and my tie rods are worn, so i figure that has something to do with it, along with worn steering componets...
wild70stang
317
  • Dec 10, 2007
I think I found the culprit. My brother (army mechanic) told me to check the fuel filter. And boy when I changed it out a dark red brown fluid came out. I should have bought a clear fuel filter in the first place, so now im sticking with them to know when to change them (changed it last summer, stupid me). Also that fluid was an indication that I have rust in my tank so now im going to either replace the gas tank or look for some kind of dissolvent. I wont be able to see if it works since after I started my car it began to shake really bad, which means that my carb is now gummed up.
Az Pete
711
18
49
Panama City, Fl.
Dec 10, 2007
  • Dec 10, 2007
I recommend replacing the tank as they are cheap and you may never get the old one clean. You will also have to flush you lines and the last thing is to clean the carb.
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
G
Resolved Please help! (starting issue)
  • Ghoste
  • May 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2025
Ghoste
G
J
Hello all, I have returned from a hiatus... Update and Questions
  • JackH
  • Aug 13, 2025
1974 - 1978 Mustang II Talk & Tech Aug 15, 2025
JackH
J
Crank no start, I’m stumped!
  • Seth Brogan
  • May 18, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 14, 2026
BossHorseGirl
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Wednesday at 4:28 AM
2v_johnny
