jerkyness when into the throttle..?
  • Thread starter Thread starter Paul Perreca
  • Start date Start date Nov 19, 2005
First Prev 2 of 2
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Nov 21, 2005
#21
  • Nov 21, 2005
  • #21
Good catch Paul..likely you've found the problem. Now you get to see how fun/frustrating modding a car is...trust me it's worth it in the long run.MAKE SURE you keep us updated on how you like the mill, and how it's running.
Paul Perreca
1,085
#22
  • Nov 21, 2005
  • #22
well it runs really friggen good - but now it's still bucking in 3rd gear, it's gay - but earlier i really ripped those tires apart in 2nd gear shift lol i couldn't beleive it was like if i didn't have wheel hop, i woulda been doing a burnout at like 25 miles per hour lol but now it's raining so i can't test out the bucking in 2nd gear shift nemore - i can't wait to get pics for you guys - i'm waiting for the next nice day so i can take them outside cuz the sunlight makes it look really nice - that strut tower brace is really cool - and other than that 3rd gear bucking - every girl at my college stares as i go past cuz you can't help but wonder what the **** is makin all that sweet noise!!
Paul Perreca
1,085
#23
  • Nov 21, 2005
  • #23
it's better than spending time thinkin about my girlfriend or ex girlfriend or whatever she is right now - thank god we broke up at the high point in my mustangs life, or else i'd care more n prob be depressed, but im not - just tonight cuz it's rainin lol
oh yea, n the surging idle is still there, it goes away by the time i'm at the end of the block lol its the gayest thing ever, but i can deal w/ it - as long as its not affecting my performance
darthcual
985
Arlington, TX
Nov 21, 2005
#24
  • Nov 21, 2005
  • #24
Hmmm what did you do about your flywheel/clutch when you had the motor out? A greasy flywheel can cause the symptoms your describing.
Paul Perreca
1,085
#25
  • Nov 21, 2005
  • #25
new clutch, and resurfaced/cut flywheel
old_blue
1,783
282
124
Nov 21, 2005
#26
  • Nov 21, 2005
  • #26
how are the pro streets sounding?? did you dump em?
Paul Perreca
1,085
#27
  • Nov 21, 2005
  • #27
no i have tailpipes, and they are the greatest mufflers ever - i'll never go back to anything else - lol but the car is still bucking annoyingly while cruising - can't wait till i figure that one out!
old_blue
1,783
282
124
Nov 21, 2005
#28
  • Nov 21, 2005
  • #28
someone else on here just got a set too (spintechs). I found a guy on ebay who can get them for me $145 shipped to my door. Hopefully this paycheck I will be able to get them.
mac16
51
#29
  • Nov 22, 2005
  • #29
man i need to hear a soundclip of prostreets with tailpipes
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Nov 22, 2005
#30
  • Nov 22, 2005
  • #30
Paul like stated earlier get some codes from the car..that's the best way to approach it...the problem is not internal, and can be fixed. Good luck and enjoy it, the car sounds like a bucket of fun.
Paul Perreca
1,085
#31
  • Nov 22, 2005
  • #31
r u sure its not internal?
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Nov 22, 2005
#32
  • Nov 22, 2005
  • #32
if the engine runs with 90 or so percent of the time without a hitch..I'm far from inclined to look at an engine problem. You indicated the car is making great power...idles good, good temp, good oil pressure...don't worry about the engine. What you need to find is what is causing the buck..is the spark cutting out?...is fuel dropping off?..or is the computer involved. First things first like said before and sorry for repeating, you need the codes to see if the car is trying to tell you what the problem is..otherwise your just guessing and or endup throwing parts at it..I've done that and it can get VERY expensive and still leave you wondering.The answer is there..you just need to find it, it's all part of the fun of working with a modified computer controlled vehicle
Paul Perreca
1,085
#33
  • Nov 22, 2005
  • #33
yea i have a converted mass air car so i will be buying that code reader to make it easier - i will def get the LCD digital one that straight pulls up the codes w/ o counting blinks lol - where is there a post or thread on Every code and what that code means??
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Nov 22, 2005
#34
  • Nov 22, 2005
  • #34
http://www.50tech.com/forums/viewtopic.php?t=3290
Paul Perreca
1,085
#35
  • Nov 22, 2005
  • #35
thanks - i'll be getting IAC today i think, and after taht whether it works or not, i'll get a code reader just to be safe and for future use, beings I'm gonna have this car a very long time -
Paul Perreca
1,085
#36
  • Nov 22, 2005
  • #36
Could my injectors be too big? My mechanic is convinced that 19 lb injectors are big enough for what i have - he said the hp curve would fall off a bit sooner like 6000 RPMS - but the torque curve would be a lot nice - is this crap true? cuz i aint takin them back out cuz i'd have to take the plenum off - and i asked a thousand times on here and every single answer was "GO WITH 24 LB INJECTORS" so i took mustang only ppl's advice, n now this guy says - i don't care what anybody else said they are too big - god DAMNIT - he said the TPS sensor too though before i told him my injector size - i really gotta dial that thing in -
E
emagdnim
391
15
28
Nov 22, 2005
#37
  • Nov 22, 2005
  • #37
Your combo definatly fits 24lb injectors, you would be having to MAX out 19lb'ers and run much higher fuel pressure and you would probably still run lean.
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Nov 22, 2005
#38
  • Nov 22, 2005
  • #38
Paul 24's are perfect for your combo..the 19's would be on the high end of output to meet your needs, though they would work, the situation is better the way it is. You may have hot start issues..some surging when warm..I do, but that's the only common issue with 24's. Guys on here have FAR more experience with the modified mustang and it's parts than the general mechanic.
First Prev 2 of 2
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
