junior windsor heads
I have them. I'm not sure of the valve size, I think they're pretty large, but they are fine with the stock pistons. The only thing that may be a problem is that it will limit which cam you use, assuming you upgrade. My advice is go with bare castings and have the heads put together for you, the valve springs that come with the heads are junk. Get them ported and polished while you're at it.
