Junkyard/Intake
slow5.0gt
138
Hey again everyone its a long shot but I was curious to know if anyone could tell me if the intake off of any other fords just the upper will fit on a 5.0 performer manifold lower intake.
Reason being is that the upper intake has a hole where the one of the bolts slide in at the end so its not snug on top of the lower intake letting in air.
Should I just try and scrounge the junkyards for an upper intake to replace it or would i just have to buy a new upper manifold....
if you are wondering what type its the first one.
http://www.jegs.com/webapp/wcs/stores/servlet/product2_10001_10002_747526_-1
There are no factory ford intakes that will fit an Edelbrock lower.
Buying a new upper manifold to repair a hole (I'm not quite sure what you mean by that, pictures would be helpful) would be a real waste of money.
Since you have to remove your current upper no matter what, the smart and economical thing to do would be to take it to an engine/machine shop and simply have the damage repaired. Odds are the repair will cost much much less than buying a whole new upper, and it will be functional.
Yeah man Im a little lost about the "hole" your talking about. Is the intake broken? That intake on your motor is probably not doing any good without any sort of cam, exhaust, or throttle body. More air in, more air out. Buy a stock Mustang upper and lower for $50, and invest money in your exhaust before your intake.
Heh days i really need a camera, the best way i can explain it is that I currently have 7 bolts in the upper intake to bolt it to the lower intake the 8th one is on the corner closest to the drivers side.
On brand new manifold there are 8 places to slide in a bolt to torque it onto the lower intake excluding the one inside the intake. IIRC
However the 8th bolt location closest to the drivers side where you can slide a bolt through it to tighten onto the lower intake is broken comletely off.
If you look at it with the upper and lower connected without it being in the engine you will notice that there is a gap between the lower and the uppper intake where the bolt usually slides into.
Take a look at the picture of the gasket and youll see where the bolts coincide with the intake and just picture one of them at the end completely missing.
When I took it to a shop to see if i can get it repaired they claimed that it would do no good to me because it will not be torqued down enough in that corner and therefore still leak.
