Just a 2v
Hey guys I wanted to share my build with you. It's been a 7 year project and it's finally starting to come together. It's a 2000 gt with a 4.6 2v
-cobra crank
- Manley rods
-custom cut diamond pistons
-trick flow twisted wedge heads
-custom grind comp cams (specs very similar to cms stage 3 blower cam)
-kenne bell 2.6
-built th400
-Neil chance converter
-chromoly shaft with 1350 joints
-35 spline axles
-minispool
-Aerospace brakes
-all mm suspension front to rear heavy duty torque arm, panhard bar, weld in rear sway bar, k member, caster camber plates, coilovers with tokico adjustable shocks and struts.
-engine is powered by a Holley dominator
I'm sure I'm forgetting so much but it gives you an idea of what I have going on.
Check out my build series I just started on YouTube and let me know what you think . Trying to get more subscribers to follow the build.
View: https://youtu.be/Z4-1BWuLulU
