Just Bought A 2001 SVT Cobra (pics)
Mar 22, 2006
38
Hey everyone. I just picked up a 2001 Covert. Cobra with Performance Red Exterior and Dark Charcoal interior. It is all stock and was very well taken care of. I paid 15,988 for it with 30,000 miles. Tell me what you think. As I have heard from many of the posts I do get some notchy shifting only when cold (double clutch to avoid grinds until warm) and once in a while a slight bump from the rear. The seats are awesome and it handles and brakes very well. The top goes down in under 10 seconds and can be easily done by one person. The only thing I may add is an exhuast and some rear end gears to shorten the long ass gears.
get her lowered, some rims, and the exhaust and the car will look great!! way to represent the new edge cobra crowd. there dont seem to be too many around any more. we gotta stick together
why does the hosting service have **** ads? im not offended, but others might be
Looks really clean, nice color choice as well.
Hopefully you don't run into any problems with the transmission. It's a T-3650 and there is a HUGE issues thread on this forum if you look around for it. Might want to check and make sure the fluid isn't low.
Used on transmissions without synchros.
When you need to shift gears, the clutch pedal gets depressed part way as you shift into neutral. Then as you shift through neutral to the next gear, you push the clutch pedal all the way in. Basically.
Thats not double clutching. Thats speed shifting. Thats the fastest way to get a modern transmition into the next gear but it is hard on the transmition.
The shifter, rather than going straight to the next gear, makes a stop in neutral and then the clutch is released. This is to allow the engine to slow down (or with a tap on the gas, speed up when downshifting) so the transition into the next gear is much more smooth. The driver then depresses the clutch again and completes the shift into the target gear, and finally the clutch is released again, putting the car back into gear. It only takes a split second for the engine speed to match the speed of the gears, so the entire action is done very quickly as a fluid sequence of events.
