just bought a cobra intake
the 1250 is larger then the ports on the stock heads and intake
a stock felpro set should fit just fine..u can most likely re-use the upper to lower gasket
rj: i have my used cobra intake i could have parted with for 300 bucks. the upper was extrude honed, the lower ported by me and i have the gasket, bolts, egr valve, egr valve to header tube, etc. i wish i would have known u were in the market 4 one.
Swarzkopf said:
Are you talking about using the stock manifold's upper to lower gasket on a Cobra manifold?
If so, NO, you definitely can not do this.
i was talking about the lower to heads gasket.
im not sure if the cobra intake has larger lower ports then the stocker but since your not changing the heads that port isnt gonna change and stock gasket (new of coarse) can be used
