Just bought a used C&L MAF have question.
_Capricious_
I just bought a used 80mm C&L MAF and one of the little sensors is broken on one side. Can I solder it back on or will it affect the sensor? I got 38lb injectors with it as well, so the sample tube is what changes the signal right? The MAF sensor that is bolted onto the meter is factory. Can I just replace it with another factory one?
thanks
Those broken wires mean the electronics are junk...
You can use the electronics from another factory meter if you have it, that is how the C&L works.
To change the calibration the sample tube simply gets swapped out, about $25 from C&L.
