Just Bought Longtubes>
  • Thread starter Thread starter Bosko5.0
  • Start date Start date Dec 4, 2006
Bosko5.0
1,067
longwood, FL
Dec 4, 2006
  • Dec 4, 2006
well just bought longtubes and mid pipe and i plan on wraping them up.
I was just curious where i should place my wideband sensor? in the LTs or the midpipe?
WhiteDevil
2,717
San Diego
Dec 4, 2006
  • Dec 4, 2006
I have shorties now and i have the wideband down in the midpipe. Im going long tubes very soon and it wills stay in the mid-pipe.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Dec 4, 2006
  • Dec 4, 2006
You should look at the info that came with your WB
Some brands don't take the heat as well as others
Grady
Stanger007
2,015
Baton Rouge, LA
Dec 5, 2006
  • Dec 5, 2006
I have MAC L/T's and a LC-1 sensor... put the sensor at 2 o'clock in the passenger side of the H-pipe about 2 inches from the collector.
Wes
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Dec 5, 2006
  • Dec 5, 2006
I put mine in the collectors of my LT's because I had seen quite a few other self tuning peeps have issues with their narrow band O2's cooling too much during idle.
I have seen peeps put bungs for nb's and wb's in a wide range of distance from the exhaust port.
That was the reason I suggested you check with the maker of your choice of wb.
Just a heads up on the header wrapping thing ...........
I've seen some say it causes them to hold moisture thus causing them to have a shorter life span
Grady
Bosko5.0
1,067
longwood, FL
Dec 5, 2006
  • Dec 5, 2006
they are bbk ceramic coated LTs so i dont think i have to worry about the moisture to much i hope, i want to wrap them so there is alot less engine bay heat, and since i have an auto its going to be a very tight fit so less heat on the tranny.
as long as they last 1 year an 3/4. i should be good.
read their instructions it didnt say so I'll give them a call
thanks for your input
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Fox Removing smog only questions
  • 91GTstroked
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
91GTstroked
T
Digital Tuning Hello OBD2 problem
  • TNmach1
  • Sep 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 18, 2026
TNmach1
T
Progress Thread Hello from Nashua, NH
  • sevenup
  • Oct 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
sevenup
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
