I did at three tests per cylinder trying very hard to turn the car over the same number of tries (3). My readings varied from the lowest @ 119 lb. to the highest @ 128 lbs. Can anyone tell me if these numbers are OK? I know that you shouldn't have a large difference between two consecutive cylinders but my concern is not a blown headgasket or broken piston. I just wanted to see what condition the motor is in before installing my H/C/I.
PS - the engine is stock with 82K miles and uses a little more oil than I'd like.
