The B&M Hammer shifter does not change how the transmission works at all. It is merely a ratchet shifter that replaces the stock shifter. You use it to put the transmission in 1, 2, D, N, R, or P using a ratched motion. If you are in 1 and push the handle forward, it will shift to 2. If you push it forward again, it will shift to D. If you push it forward again, it will shift to N. To shift to OD, you push a button. If you are in D and pull the handle back, you will shift to 2. Pull it back again, you will shift to 1. The transmission will react exactly the way it does if you shift into these gears with the stock shifter. If you want total control over your gear selection, you also need a manual valve body. The manual valve body will cause the tranny to shift instantly to the gear you select and the shift will jar your teeth out.
