I just finished installing typhoon intake, 42's, 80mm Pro-M, Summit radiator, and a Vortech S-trim. I also did the fox TB style swap. My two problems are that I cant find a belt to go with my smog deleted. I tried various sizes and nothing. The next problem is that when I started up the car for the first time it revved up to 3K and stayed there.
I spoke to Vib and he said I most probably need to get a smog pump delete kit. The problem with my belt was that I kept getting a smaller size belt but the tensioner was still to its loose position. Dont know why, and the tensioner still works fine so it cant be that.
The other idle problem Vib said it could be from the TPS being messed up. I need to try and get it close to .94 I think he said. Also, since I did the fox TB swap I needed to change the connectors for the TPS, so I wanted to make sure I connected it right. So if anyone know please chime in.
How can I get the car to run decent for now? I am getting the tweecer soon, but until then I need to manage with something.
