  • SN95 4.6L Mustang Tech
Just installed my UPR O/R X-pipe....OMFG!!! Wow.....
  • Thread starter Thread starter Craig Mack
  • Start date Start date Dec 10, 2003
  • 3
First Prev 2 of 3 Next Last
01'TRUE BLUE GT
4,984
Pittsburgh, PA.
Dec 11, 2003
#21
  • Dec 11, 2003
  • #21
I wish I had a buck for every time I heard the word "rasp" in here. My X doesn't have any rasp ... Hey! ... There's another buck.
Craig Mack
Busted Buffing the Bishop
801
Lake Mary, FL
Dec 12, 2003
#22
  • Dec 12, 2003
  • #22
Rasp? Who is saying rasp? All X-pipes make some amount of rasp, but rasp can be a good thing. Rasp can sound really cool, and rasp can also sound really bad. My pipe sounds awesome, but has an unusual amount of new rasp to it that I didn't expect. The rasp sure sounds metallic, but I guess that is rasps nature. H-pipes dont usually have rasp, but h-pipes sound boring. X-pipes sound unique, and with the unique comes a little rasp, but I have more rasp then a little bit. So that's why I posted my previous question, to address the issue of the raspyness of my pipe. I sure hope the AAMCO guys can figure out of a washer or something is causing the rasp, b/c I hope the pipe isnt supposed to rasp this much naturally.
I sure hope I can do something to fix this rasp, if anyone has any ideas about the rasp or can relate to the amount of rasp I am getting, please post. Title your post rasp so that I know its about the rasp and not something else.
D
DerekStangGT
My package is in the mail!
Feb 18, 2003
1,068
Dec 12, 2003
#23
  • Dec 12, 2003
  • #23
nickthegenius said:
I have the UPR X-pipe and really like it too. Especially for $150-shipped....you can't beat it.
$150 shipped?!?!?!?!? i was just about to pay $130 for Flows shipped!!! screw that!! im gettin a UPR where did you buy yours??
I
inertia
113
TEXAS
Dec 12, 2003
#24
  • Dec 12, 2003
  • #24
congrats
steelcityGT
Glenshaw, pa.
Dec 12, 2003
#25
  • Dec 12, 2003
  • #25
I have a brand new one sitting in it's carton. It will fit 99 and up I'll ship it to
you for $110. I just bought a new Mach and am going with a full Bassani system
send a PM or email drm@concast.com
68 & 00 GT
2,407
HOUSTON TEXAS
Dec 12, 2003
#26
  • Dec 12, 2003
  • #26
Good luck finding a loose washer, or bolt. Most likely that's just how your exhaust sounds now. Take your car to the track, and drive the hell out of it, and see if that quietens it down some. When my set up got some miles on it I guess the exhaust build up inside made it a little quieter, and less raspy. I drove a friends 02 with your set up though and didn't like how it sounded at all. Not smooth anymore. If it doesn't tone down just get some Magnaflows , or Magnapacks (if you want louder). I promise that will not dissapoint you. Absolute ear candy.
White360RFnSwee
869
West Palm Beach FL
Dec 12, 2003
#27
  • Dec 12, 2003
  • #27
Yes, UPR pipes are dirt cheap...
Im replacing my catted VRS pipe with one.. I recently replaced my magnapack catback on my 03 cobra with 3 chamber flowmasters.. and Im going to open it up. one of my cats is clogged so we will see.. I may just weld up some magnaflow mufflers if it is too loud..
-Ryan
Craig Mack
801
Lake Mary, FL
Dec 12, 2003
#28
  • Dec 12, 2003
  • #28
Is it possible that it sounds more raspy inside the cabin then to the people outside? And, is that "it quiets over time" stuff a fact or myth? Becuase I know my mufflers havent gotten any quieter or louder, and I don't remember if previous exhausts on my other car quieted over time. Hopefully it's not just a happy thought.
White360RFnSwee
869
West Palm Beach FL
Dec 12, 2003
#29
  • Dec 12, 2003
  • #29
only straight through mufflers have any type of break in period... chambered do not.
-Ryan
Venom4.6
1,356
Saint Louis, MO
Dec 13, 2003
#30
  • Dec 13, 2003
  • #30
http://www.uprproducts.com/shopping/shopexd.asp?id=301
chevylover
190
Castro Valley, CA originally St. James Missouri
Dec 13, 2003
#31
  • Dec 13, 2003
  • #31
The UPR x-pipe will bolt on to a stock system or did you have to make some mods. I'd love to put an X-pipe on but don't have access to a welder and putting this on would save atleast $250 over going with a bassani and having it put on at a shop.
Craig Mack
801
Lake Mary, FL
Dec 13, 2003
#32
  • Dec 13, 2003
  • #32
No welding needed for the UPR. Comes in two peices which makes install much easier. I really like the Dr. Gas, but that would cost $400-500 installed. Screw that.
COBRA90GT
Mustang Master
Sep 22, 2001
6,654
HOCKEYTOWN ® , MI
Dec 13, 2003
#33
  • Dec 13, 2003
  • #33
Be sure to disconnect your battery (if you haven't already).
As long as you installed the MIL elims correctly and didn't damage your O2 sensors (and re-installed them in the correct location/bungs after swapping them to the new pipe), the CEL shouldn't turn on because of your new pipe. Maybe there's a slight leak? Might want to re-tighten the bolts just in case.
The CEL could be associated with another, entirely unrelated problem...try to get it scanned for codes if resetting the PCM/battery doesn't do the trick.
Craig Mack
801
Lake Mary, FL
Dec 13, 2003
#34
  • Dec 13, 2003
  • #34
If I got the o2 sensors dirty would that make any difference? I got a little grease on them, my hands were filthy. I was drenching all the bolts with liquid wrench anti seize lubricant. I can't see that hurting anything though, since the sensors are exposed to scorching exhaust gases everytime the car is ran. If I accidently mis matched the sensors, would that make a difference? My car is at the tranny shop now, and they told me the o2 sensors looked fine. Unlike me, they have power tools so when they bolt the pipe/sensors back on, it will be tight for sure. I hope the MILs I was sent weren't duds.
Venom4.6
1,356
Saint Louis, MO
Dec 13, 2003
#35
  • Dec 13, 2003
  • #35
Mismatching the front o2 sensors isn't a problem because they are the same. The rear o2's are different though so make sure they are put back in the proper spot. Fouled sensors with grease can cause them to fail.
nickthegenius
1,631
Elwood, IN
Dec 13, 2003
#36
  • Dec 13, 2003
  • #36
I haven't looked at this thread in a while. I got it off of Ebay. UPR lists quite a few items on there. Here is a current auction for a '99-up GT X-pipe:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33633&item=2448202720
Craig Mack
801
Lake Mary, FL
Dec 14, 2003
#37
  • Dec 14, 2003
  • #37
I am 99% sure I put the rear sensors in right. Hopefully AAMCO will put them in their correct places. I didn't know grease could hurt the sensors...****.
R
Redponyxpress
129
Winder, Ga=redneck capitol of the world
Dec 14, 2003
#38
  • Dec 14, 2003
  • #38
WHATS THE DEAL WITH THE "OMFG"?!! NOT GOOD. NOT GOOD AT ALL!!
DB96GT
385
AZ
Dec 16, 2003
#39
  • Dec 16, 2003
  • #39
Not to hijack.
I'm not sure what you guys mean by rasp. I just installed a catted Bassani X pipe with my Mac Flowpaths and though it sounds pretty damn good, it REALLY resonates loudly at about 2000 rpm. I'm not sure if it's just because it's louder, or because of the X and chambered muffler. But I hear something in my dash rattle because now because it's so loud. It's almost like the exhaust is touching the body of the car somewhere - it's not though.
Is that rasp?
D
DerekStangGT
Feb 18, 2003
1,068
Dec 16, 2003
#40
  • Dec 16, 2003
  • #40
i agree
  • 3
T
Losing Refrigerant rapidly on my 98 Mustang GT
  • TekoSn95
  • Jun 21, 2025
SN95 4.6L Mustang Tech Aug 17, 2025
TekoSn95
T
O
My rebirth, Hi from PA
  • onemore1987
  • Jun 28, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2026
onemore1987
O
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
