I wish I had a buck for every time I heard the word "rasp" in here.
My X doesn't have any rasp ... Hey! ... There's another buck.
01'TRUE BLUE GT said:I wish I had a buck for every time I heard the word "rasp" in here.My X doesn't have any rasp ... Hey! ... There's another buck.
nickthegenius said:I have the UPR X-pipe and really like it too. Especially for $150-shipped....you can't beat it.
screw that!! im gettin a UPR
where did you buy yours??
68 & 00 GT said:Good luck finding a loose washer, or bolt. Most likely that's just how your exhaust sounds now. Take your car to the track, and drive the hell out of it, and see if that quietens it down some. When my set up got some miles on it I guess the exhaust build up inside made it a little quieter, and less raspy. I drove a friends 02 with your set up though and didn't like how it sounded at all. Not smooth anymore. If it doesn't tone down just get some Magnaflows , or Magnapacks (if you want louder). I promise that will not dissapoint you. Absolute ear candy.![]()
http://www.uprproducts.com/shopping/shopexd.asp?id=301DerekStangGT said:$150 shipped?!?!?!?!? i was just about to pay $130 for Flows shipped!!!screw that!! im gettin a UPR
chevylover said:The UPR x-pipe will bolt on to a stock system or did you have to make some mods. I'd love to put an X-pipe on but don't have access to a welder and putting this on would save atleast $250 over going with a bassani and having it put on at a shop.
Might want to re-tighten the bolts just in case.COBRA90GT said:Be sure to disconnect your battery (if you haven't already).
As long as you installed the MIL elims correctly and didn't damage your O2 sensors (and re-installed them in the correct location/bungs after swapping them to the new pipe), the CEL shouldn't turn on because of your new pipe. Maybe there's a slight leak?Might want to re-tighten the bolts just in case.
The CEL could be associated with another, entirely unrelated problem...try to get it scanned for codes if resetting the PCM/battery doesn't do the trick.
Venom4.6 said:Mismatching the front o2 sensors isn't a problem because they are the same. The rear o2's are different though so make sure they are put back in the proper spot. Fouled sensors with grease can cause them to fail.
Redponyxpress said:WHATS THE DEAL WITH THE "OMFG"?!! NOT GOOD. NOT GOOD AT ALL!!![]()
i agree
