just installed tranny
  • Thread starter Thread starter torch93
  • Start date Start date Jan 18, 2011
torch93
143
bakersfield c.a
Jan 18, 2011
  • Jan 18, 2011
hey guys quick question, i just installed a t 5, and when i push in clutch and try to put into 1st it grinds a lil, i haven't drove it due to h pipe not installed but i added the 3 quarts of tranny fluid and tried to go to gears and notice it.. could it mean that i need to drive it to get the oil mixed around or tranny bout to go?
01GTSTANGER
100
Pasadena, CA
Jan 18, 2011
  • Jan 18, 2011
Is this transmission new?
HISSIN50
34
129
Jan 18, 2011
  • Jan 18, 2011
And is the clutch completely disengaging?
Cobra1741
152
  • Jan 18, 2011
id be willing to bet you need to adjust the clutch
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 18, 2011
  • Jan 18, 2011
Clutch adjustment
Do the clutch adjustment first before considering any other problems. With the stock plastic quadrant and cable, pull up on the clutch pedal until it comes upward toward you. It will make a ratcheting sound as the self adjuster works.
Clutch pedal adjustment with aftermarket quadrant and cable: I like to have the clutch completely disengaged and still have about 1.5” travel left before the pedal hits the floor. This means that I have only about 1” of free play at the top before the pedal starts to disengage the clutch. Keep in mind that these figures are all approximate. When properly adjusted, there will not be any slack in the clutch cable. You will have 4-15 lbs preload on the clutch cable.
torch93
143
bakersfield c.a
Jan 18, 2011
  • Jan 18, 2011
It's a used tranny wait a " rebuilt tranny" I only switched the tranny and left my old bell housing on so I didn't take off my clutch, with my other tranny it didn't do it.. I was seeing if it could be low on tranny fluid or bad tranny?
torch93
143
bakersfield c.a
Jan 18, 2011
  • Jan 18, 2011
ok check this, i just got back from a cruise with new tranny and gotta say it holds really good. now that 1st gear grind i was talking about is only when i quickly throw into first from neutral .. but if i go into 2nd and then throw it into 1st pretty quick (at a stop of course) or if i just slowly put it into first then it will not grind at all
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 19, 2011
  • Jan 19, 2011
Check the clutch pedal adjustment, even if it didn't seen to need it before you replaced the transmission. It will take you 1 minute with the stock adjuster and maybe 30 minutes if you have to jack the car up to adjust an aftermarket adjustable clutch cable. A setup with a firewall cable adjuster will take less than 5 minutes.
The other alternative is that the transmission syncros are worn out and need replacing.
capri debris
289
PA
Jan 19, 2011
  • Jan 19, 2011
Cable adjustment, bad syncro or pilot bearing.
Pilot bearing is the most forgotten thing to check when getting grinding gears.
When you push the clutch in, the desired effect is for the flywheel to keep spinning, but the tranny input shaft to come to a rest. If the pilot bearing is bad, it will keep the input shaft of the tranny spinning and make the syncros work harder to stop it from spinning.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 19, 2011
#10
  • Jan 19, 2011
  • #10
He's absolutely correct.
I had a cheap Chinese (Advance Auto Parts) wear out and damage the pilot bearing surface. The transmission was hard to shift and ground in almost every gear. It took a new input shaft, pilot bearing and a lot of sweat and effort to remove the trans, replace the input shaft put it all back together. There was $175 worth of parts and $25 to get the bearing pressed off the old input shaft and on to the new input shaft. I learned never to go cheap on pilot bearings...
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
